map_suite_web_edition_spatial_functions_samples
Map Suite Web Edition Spatial Functions Samples
Clipping On Line Layer
Create Inner Ring
FeatureIdsToExclude
Get Feature Clicked On(Web)
Applies To: Web \ Silverlight
Get Feature Clicked On(Web)2
Intersect Line
Polygon Shapes To Multipolygon Shapes
Shortest Line Between Two Features with Split
Applies To: Desktop \ Web \ MVC \ Silverlight \ Services \ WPF
This sample will show you how to find the closest line between two features by using the <tt>GetShortestLineTo</tt> API and how to split a line at a given point using the <tt>GetLineOnALine</tt> API. These APIs can be very useful when doing spatial analysis and editing of features. This sample also allows you to dynamically alter the test features using the <tt>EditOverlay</tt> so you can try out different scenarios and see the results quickly. A MapShapes layer is used to display and style the individual results.
Sweep Angle Desktop
Clipping
Convex Hull
Correcting Nodes
Create Polygon Programatically
Dissolve on Shapefile
Draw a Pie shape
Dynamic Segmentation
Get Feature Clicked On With Projection
Identify Point with Icon
Inner Ring Containment
Intersecting Multi Polygon
Intersecting Two Layers
Merge Line Layers
Merge Point Layers
Merging Layers
Multi Ring Buffering
LEAD Technologies Inc. V1.01
Negative Buffering
Offset Point at Right Angle
Register Shape
Remove LineShape
Spatial Join
Split Polygon
Split Polygon Based On Grid
From the Performance Guide:
Split Polygon Dynamically into Grids based on the Area
Sweep Angle
Splitting Polygons with a Line
map_suite_web_edition_spatial_functions_samples.1441776740.txt.gz · Last modified: 2015/09/09 05:32 by admin
