map_suite_web_edition_quick_start_guide
Map Suite Web Edition Quick Start Guide
The Map Suite Web Edition illustrated QuickStart Guide will guide you through the process of creating a sample application and will help you become familiar with Map Suite. This edition of the QuickStart Guide supports Web Edition 9.0.0.0 and higher.
Welcome to Map Suite™ Web Edition from ThinkGeo, a full-featured mapping control that makes it easy for any Microsoft .NET developer to add mapping functionality to a Microsoft .NET application quickly and efficiently. Using the intuitive object model, even developers inexperienced in Geographic Information Systems (GIS) can have fully functional maps working in minutes.
Before we get started, make sure that you have installed the ThinkGeo Product Center and that you have either started an evaluation or activated a full license of Map Suite Web Edition. By default, this will install the Map Suite Web Edition 9.0 assemblies to C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite Web
Download the Sample
Setting up the Environment
Let's start with a new ASP.NET Web Site in Microsoft Visual Studio (2010 or newer) and call it “HelloWorld” (see Figure 1). Set the Templates to “.NET Framework 4.0” for the project.
Figure 1. Creating a new project in Visual Studio.
The website is created in a new solution called “HelloWorld”. The wizard creates several files including a Web form called “Default.aspx”.
Adding the Map Control to the Visual Studio Toolbox
1. When you first open Microsoft Visual Studio after installing Map Suite, you may not see the control in the Toolbox. You will need to follow these steps to add the control.
Hover over the Toolbox and right click anywhere on the list of controls. You will get a pop-up menu. Select “Choose Items…”
2. The Choose Toolbox Items dialogue will appear. You will need to select the “.NET Framework Components” tab and then click the “Browse…” button. Finally, navigate to the C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite Web\Current Version\Managed Assemblies folder and select the “WebEdition.dll” file.
3. You should now have the Map Control available in your Toolbox as shown in Figure 2 below.
Figure 2. The Map Control in the Toolbox window.
Adding the Map Control to your Web Form
We need to add “MapSuiteCore.dll” to the reference. Right-click the project in Solution Explorer and select “Add Reference…”, navigate to the C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite Web\Current Version\Managed Assemblies folder and select “MapSuiteCore.dll”.
Note: Although it is not a ThinkGeo assembly, you also need to add “WindowsBase.dll” to the references. WindowsBase can be found on the .NET tab of the Add Reference dialog. If you don't do this, you will get the following error when you compile the project: “The type 'System.Collections.Specialized.INotifyCollectionChanged' is defined in an assembly that is not referenced. You must add a reference to assembly 'WindowsBase, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'.”
Draw the Map control on the web form by clicking on the Map Control object in the Toolbox and then dragging and dropping (using the left mouse button) to the size you desire. You can leave the name of the Map control set to “Map1”. This is the control in which our map will display.
Now that we have “MapSuiteCore.dll” referenced and a Map Control added. We are ready for adding the code.
Map Suite Web "Hello World" Sample
After this section, you will be able to draw a map with Map Suite Web Edition using your own data. At the very beginning, let's have a look at the data and the important objects we will use.
Shapefiles
Map Suite Web Edition 9.0 supports multiple kinds of data sources, such as SQL Server 2008, Postgre, Oracle, etc. Here we will provide an introduction to Shapefiles which we will use in this Quick Start Guide.
ShapeFileFeatureLayers
Map
A Map object is the highest level object that encompasses layers and some other objects. For now, you can think of a Map as a set of layers, which can render each layer and present you with a map based on actions performed, such as moving in and out, or panning across the surface to view another part of the map.
Styles
Shapefiles provide the data, but Styles are the way you color and draw them. You can specify the color of the country, the width of a road, the shape (triangle, circle, cross etc) of a point, and so on.
Map Suite has many preset Styles built in, including predefined Styles for roads, rivers, cities, countries, and more. This makes it easier to create great looking maps without a lot of hassle.
PresetZoomLevels
PresetZoomLevels has a very useful property called ZoomLevel.ApplyUntilZoomLevel, which you can very easily use to extend your ZoomLevels. Let's say you want a particular Style to be visible at ZoomLevel03 through ZoomLevel10. To make that work, we can simply code as follows:
worldLayer.ZoomLevelSet.ZoomLevel03.DefaultAreaStyle = AreaStyles.Country1;
worldLayer.ZoomLevelSet.ZoomLevel03.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level10;
In creating our “Hello World” sample application, our first step is to set a reference to the Map Suite Core workspace at the very top of our code, as we will use many classes within that. We do this so that we do not have to use the fully qualified name of the Map Suite classes throughout our code. Setting a reference to the Map Suite workspace can be done in the “code-behind” of the Form by selecting the Form and hitting the F7 function key. Set the reference like this:
using ThinkGeo.MapSuite.Core;
  • The borders of every country in the world (“cntry02.shp”)
Our next step is to define and add our layers. All of our sample code is placed in the Page_Load event of the web form. We also will want to put in a check for whether the page is posting back. This is so our Map control can load and render the data only once, during initial load, instead of repeatedly every time a post back to the web server is made. For the sample application we are making here, this check is not actually needed, as there will not be any PostBack in this application. Still, this is a good coding habit for a Web project, so let's put in the code to check for post backs in first. Then, we'll put our other code inside that structure.
protected void Page_Load(object sender, EventArgs e)
        if (!IsPostBack)
            // Set the Map Unit. The reason for setting it to DecimalDegrees is that is what the shapefile's unit of measure is inherently in.
            ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(MapPath("~/App_Data/Countries02.shp"));
            // Set the worldLayer with a preset Style, as AreaStyles.Country1 has YellowGreen background and black border, our worldLayer will have the same render style.
            // This setting will apply from ZoonLevel01 to ZoomLevel20, that means we can see the world the same style with ZoomLevel01 all the time no matter how far we zoom out/in.
            // We need to add the world layer to map's Static Overlay.
            Map1.StaticOverlay.Layers.Add(worldLayer);
            // Set a proper extent for the map, that's the place you want it to display.
            Map1.CurrentExtent = new RectangleShape(5, 78, 30, 26);
If you compile and run what you have now, your map should look like the one below. (See Figure 4).
Figure 4. A simple map of Europe.
NOTE: It is important that the MapUnit property of a Map object be set using the GeographyUnit Enumeration. This is because Shapefiles only store binary vector coordinates, which can be in DecimalDegree, feet, meters, etc., and our map has no idea about what the unit of measurement is until we set it. This information is normally found somewhere in the documentation or within the supplemental data file as discussed in the section on Shapefiles.
  1. The borders of every country in the world (“cntry02.shp”)
  2. The capitals of the world countries (“capital.shp”)
        if (!IsPostBack)
             ShapeFileFeatureLayer capitalLayer = new ShapeFileFeatureLayer(MapPath("~/App_Data/WorldCapitals.shp"));
             // These settings will apply from ZoonLevel01 to ZoomLevel20, that means we can see city symbols the same style with ZoomLevel01 all the time no matter how far we zoom out/in.
             // We need to add both of the new layers to the Map's Static Overlay.
             Map1.StaticOverlay.Layers.Add(capitalLayer);
The result is as follows(Figure 5):
Figure 5. Europe map with 2 layers.
How to Use the TextStyle
Textstyle
The TextStyle is used to label items on map. As every Shapefile has a related .dbf file, which includes descriptions for every record, the most common way to use the TextStyle is for labeling. For example, the Shapefile containing capitals of the world has a corresponding .dbf file that contains the field “CITY_NAME”. We can use this field to label the cities on our map.
        if (!IsPostBack)
            ShapeFileFeatureLayer capitalLabelLayer = new ShapeFileFeatureLayer(MapPath("~/App_Data/WorldCapitals.shp"));
            // We use the preset TextStyle. Here we passed in the “CITY_NAME”, which is the name of the field we want to label on map.
            // As the map is drawn by tiles, it needs to draw on the margin to make sure the text is complete after we joining the tiles together.
            // Change the number to another one (for example 0) and you can see the difference.
            // Add the label layer to Map.
            Map1.StaticOverlay.Layers.Add(capitalLabelLayer);
            // Set the background color to make the map beautiful.
            Map1.MapBackground.BackgroundBrush = new GeoSolidBrush(GeoColor.GeographicColors.ShallowOcean);
Figure 6. Europe map with TextStyle.
        if (!IsPostBack)
            // The Style we set here is available from ZoomLevel01 to ZoomLevel05. That means if we zoom in a bit more, the appearance we set here will not be visible anymore.
            // The Style we set here is available from ZoomLevel06 to ZoomLevel20. That means if we zoom out a bit more, the appearance we set here will not be visible any more.
            // We can customize our own TextStyle. Here we passed in the font, the size, the style and the color.
Can you imagine what the map will look like now? Figure 7 below is the result. At first it looks the same as it did in Figure 6. Now zoom in, and watch the map change to resemble Figure 8 as you do.
Figure 7. European cities with two ZoomLevels, before zooming in.
Figure 8. European cities with two ZoomLevels, after zooming in.
Using the Map in an Update Panel
If you put the map within an update panel, you can take advantage of AJAX. To make this clearer, we will walk you through a sample.
First, let's add a marker on the map. Our first step is to add a reference to the MapSuite.WebEdition namespace at the very top of our code:
using ThinkGeo.MapSuite.WebEdition;
Next, drag a button to the page and leave the name set to the default “Button1”. Double-click that button and write the following code in the Button1_Click method:
protected void Button1_Click(object sender, EventArgs e)
    if (!Map1.MarkerOverlay.FeatureSource.InternalFeatures.Contains("Marker"))
        // Add a new feature as a marker
        Map1.MarkerOverlay.FeatureSource.InternalFeatures.Add("Marker", new Feature(0, 52));
        // Set the marker style, and make it available all over the zoomlevels.
        Map1.MarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.WebImage = new WebImage("../../theme/default/img/marker_blue.gif", 21, 25);
        Map1.MarkerOverlay.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
Let's run the application and click the button. You will see a marker appear near London. (Figure 9)
Figure 9. Add a marker to the map.
We have now added a marker to the map; however, you will find that the map flickers every time you click the button.
The following code in “Default.aspx” shows how we can put the map control and the button within an update panel to solve the flickering problem. You can also put the button outside the update panel; see the following sets of example code for details:
Aspx code 1: Put both the map control and button into the update panel.
<body>
    <form id="form1" runat="server">
    <asp:ScriptManager ID="ScriptManager1" runat="server">
    </asp:ScriptManager>
    <asp:UpdatePanel ID="UpdatePanel1" runat="server">
        <ContentTemplate>
            <cc1:Map ID="Map1" runat="server" Height="600px" Width="800px">
            </cc1:Map>
            <asp:Button ID="Button1" runat="server" OnClick="Button1_Click" Text="Button" />
        </ContentTemplate>
    </asp:UpdatePanel>
    </form>
</body>
Aspx code 2: Put only map in an update panel.
<body>
    <asp:UpdatePanel ID="UpdatePanel1" runat="server" UpdateMode="Conditional">
        <ContentTemplate>
            </cc1:Map>
        </ContentTemplate>
        <Triggers>
            <asp:AsyncPostBackTrigger ControlID="Button1" EventName="Click" />
        </Triggers>
    </asp:UpdatePanel>
    </form>
</body>
Summary
You now know the basics of using Map Suite Web Edition and are able to start adding this functionality into your own applications. Let's recap what we have learned about the object relationships and how the pieces of Map Suite work together:
  1. It is of the utmost importance that the units of measurement (feet, meters, decimal degrees, etc.) be set properly for the map, based on the requirements of your data.
  2. Shapefiles (and other data sources like Oracle, Postgre, SQL 2008, etc.) provide the data used by Map Suite to render a map.
  3. A Map is the basic class that contains all of the other objects that are used to define how the map will be rendered.
  4. A Map has one-to-many Layers. A Layer contains the data (from shapefile or other data sources) for drawing.
  5. A layer can have one-to-many ZoomLevels. ZoomLevels help to define ranges of when a layer should be shown or hidden.
Download Sample Code From This Exercise (1.62 MB)
map_suite_web_edition_quick_start_guide.1441763419.txt.gz · Last modified: 2015/09/09 01:50 by admin
