map_suite_web_edition_miscellaneous_samples
Map Suite Web Edition Miscellaneous Samples
Context Menu with Sub Menu
Applies To: Web
Based on a discussion forum request, today's web project shows you how to add sub menus to ContextMenu. This is a built-in function in all of the most recent daily builds of Map Suite, which you can download from the ThinkGeo Customer Portal. This project also demonstrates how to enable the ContextMenu's auto wrap feature when you click on the edges of the map.
Custom Scale Bar
Draw Custom Exception
Interact with Map Points
Applies To: Web
In this web-based project, we show you how to do a two-way interaction between the features in an InMemoryFeatureLayer and their information in GridView. If you click on a point on the map, you will see the corresponding item highlighted in the GridView. Or vice-versa; you can click on an item in the GridView and you will see its feature highlighted on the map.
MDI Form
Topology Validation
Use Map with MVC Framework
Map Suite Explorer (ServiceEdition)
Tile Cache Generator
<div sample_otherlinks> [
map_suite_web_edition_miscellaneous_samples.1441771275.txt.gz · Last modified: 2015/09/09 04:01 by admin
