View Source |
View Source |
View Source |
View Source |
View Source |
View Source |
Applies To: Web \ Silverlight
View Source |
View Source |
View Source |
View Source |
View Source |
View Source |
View Source |
View Source |
codesamples
Applies To:
WMTS Overlay==== {
=78|Sample
!width=66|Product
!Description
|View Source<br><br>C# Download<br><br>Need it in another language?
|Web <br><br>Applies To: Desktop <br> Web <br> Silverlight <br> Services <br> Wpf <br>
|This project shows how to consume data from a WMTS Server using WmtsOverlay. You would find the code pretty straightforward, while behind the scenes we request tiles from the server asynchronously and efficiently, and stitch them into a proper map. <br> This class is introduced from version 6.0.187.0, besides this WmtsOverlay, we also have WmtsLayer available. Here is the WMTSLayer Sample.
