map_suite_web_edition_layers_featuresources_samples
Map Suite Web Edition Layers & FeatureSources Samples
Combining Overlays
Create GRID
Edit Attribute Of Shapefile
Edit Geometry Of Shapefile
Get Data From Server With WCF
Graphic Logo for Web
Applies To: Web \ Silverlight
Heat Map
Heat Map with earthquakes
Image Stream Loading
KML Extension Web
Latitude Longitude Graticule
Native TAB File Suppport
Numbered Grid
codesamples
WMTS Overlay
=78|Sample !width=66|Product !Description |- | |View Source<br><br>C# Download<br><br>Need it in another language? |Web <br><br>Applies To: Desktop <br> Web <br> Silverlight <br> Services <br> Wpf <br> |This project shows how to consume data from a WMTS Server using WmtsOverlay. You would find the code pretty straightforward, while behind the scenes we request tiles from the server asynchronously and efficiently, and stitch them into a proper map. <br> This class is introduced from version 6.0.187.0, besides this WmtsOverlay, we also have WmtsLayer available. Here is the WMTSLayer Sample. |}
map_suite_services_edition_layers_featuresources_samples
map_suite_web_edition_layers_featuresources_samples.1441709198.txt.gz · Last modified: 2015/09/08 10:46 by admin
