map_suite_web_edition_labeling_samples
Map Suite Web Edition Labeling Samples
Draggable Labels
Applies To: Web \ Wpf
Labeling based on size
MultiLine Labeling
Multiple Labels
This sample shows how you can display multiple labels for a given point or feature. You can do this by setting a single TextStyle or multiple TextStyles. If you use a single TextStyle, you can simply use a pattern like “ColumnName1[ColumnName2]…” and when Map Suite displays the text it will combine the values of the columns in your pattern. If you use a different styling method, you will need to manually control the offset of each piece of text to avoid overlapping.
map_suite_web_edition_labeling_samples.1441709000.txt.gz · Last modified: 2015/09/08 10:43 by admin
