map_suite_web_edition_interactiveoverlays_samples
Map_Suite_Web_Edition_InteractiveOverlays_Samples
Custom Track Line
Screenshot width=78Sample width=66Product Description
map_suite_web_edition_sample_custom_track_line.jpg View Source
C# Download
Need it in another language?
Desktop \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In today’s project, we are going to see how to extend the TrackInteractiveOverlay in the Desktop edition to have the desired behavior when tracking a line. In this case, we show how to override the MouseDownCore function to have the line being tracked at left mouse click and have the last vertex added deleted at right mouse click.
Custom Track Polygon
map_suite_web_edition_sample_custom_track_polygon.jpg View Source
C# Download
Desktop \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In the project “Custom Track Line”, we saw how to extend the TrackInteractiveOverlay to have the behavior of deleting the last added vertex when right click on a track line. In today’s project, we show how to implement this same behavior for tracking polygon.
Dragged Point Style
map_suite_web_edition_sample_dragged_point_style.jpg View Source
C# Download
Desktop \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In the Discussion Forum Post “Snapping help needed”, we show the solution to have a dragged vertex snapping to a vertex of another layer. You can see that by default the control point being dragged turns yellow. In this project, we focus our attention on how to have control on the style of the control points. You will see how to override the DrawCore function of EditInteractiveOverlay. This is a project for the Desktop edition.
Dynamic Info On TrackShapes
map_suite_web_edition_sample_dynamic_info_on_trackshapes.jpg View Source
C# Download
Desktop \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Wpf \\ This project is for the Desktop version and it shows how to handle TrackOverlay to obtain dynamic information about the shape being tracked.
EditOverlay Styles
map_suite_web_edition_sample_editoverlay_styles.jpg View Source
C# Download
Web \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In today’s Web project, we learn how to control the styles of the EditOverlay for both the default style and the editing style. In order to accomplish this, we write some javascript code. Look at the code in the “script” tag to see how we can control the fill color, the opacity, the border width etc of the features in the EditOverlay.
Select with Track Shape
map_suite_web_edition_sample_select_with_trackshape.jpg View Source
C# Download
Desktop \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Wpf \\ In today’s Desktop project, we combine the skills we learned in the samples “Spatial Query A Feature Layer” and “Track And Edit Shapes”. You can see how we use the event TrackEnded to get the RectangleShape from the tracked shape of TrackOverlay to do the spatial query. In this example, we use a Rectangle but you could also very easily use another shape such as Polygon, Circle, etc.
Tracked Shapes to WKT
map_suite_web_edition_sample_tracked_shapes_to_wkt.jpg View Source
C# Download
Desktop \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Wpf \\ In today’s project, we show how to save a tracked shape to WKT (Well Known Text). You will notice that we make the distinction between the shape being tracked and the finished tracked shape thanks to two different events of TrackOverlay, TrackEnding and TrackEnded.
Vertex Tolerance
map_suite_web_edition_sample_vertex_tolerance.jpg View Source
C# Download
Desktop \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ Basically, this project shows the opposite of yesterday’s project “Snap To Layer”. Instead of having the dragged control point snapping to a vertex if within a tolerance, we show how to not allow a control point get within a set tolerance. This technique can be handy to implement if you have a requirement to have vertices of a shape being no less than a certain distance between each others. To implement that technique, again we use the power and flexibility of the EditInteractiveOverlay of the Desktop edition.
map_suite_web_edition_interactiveoverlays_samples.1440040124.txt.gz · Last modified: 2015/09/08 10:34 (external edit)
