map_suite_web_edition_faq_styles
Table of Contents
Map Suite Web Edition FAQ Styles
Sample: Cached Value Style
How do I cluster multiple points into one point for display?
Sample:ClusterPointStyle
How do I display a label in real world dimensions?
Sample:World Sized Text Style
How do I display an icon in real world dimensions?
How do I word wrap my labels?
Sample:WordWrapped TextStyle
How do I draw features differently based on column values?
How can I display decimal degrees as degrees, minutes and seconds?
How do I display a point based on real time data such as the current time?
Sample:Time Based Point Style
How do I label each line in a MultiLineShape?
How can I show one-way streets arrows on my roads?
How do I draw a line with a different start and end style?
Sample:Start End LineStyle
How do I display the distance of a line as label?
Sample:Distance Line Style
How do I display a point as a doughnut shape?
Sample:Doughnut Point Style
How do I draw points where the size is proportional to a column value?
Sample:Sized Point Style
How do I rotate a side view icon based on its heading?
Sample:Side View Icon
Sample:EditOverlay Styles
How do I draw an icon that flashes?
Sample:Flashing Point Style
How do I make a text larger or smaller based on the current scale?
Sample:Scaling TextStyle
How do I make an icon larger or smaller based on the current scale?
Sample:Scaling Image Style
How do I create a custom style to display routes?
Sample:Routing Styles
Sample:Rotate Icon
Sample:Rotated Image Style
Sample:Vehicle Direction
How do I rotate a feature's text similar to word wrapping?
Sample:Hybrid TextStyle
This project is a follow up to the Discussion Forum post http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6652/afv/topic/Default.aspx Rotating the feature text (similar to wordwrap). In this project, we create a new Text Style combining word wrapping that we saw in the project http://code.thinkgeo.com/projects/show/wordwrapped and text rotation. You can see the labels word wrapping and rotating in harmony with the resizing and rotating of the shapes.
How do I set multiple dot density styles on the map?
How to create a cutomer valuestyle?
Sample:Default ValueStyle
How to create a line style with increment?
How do I display multi line labeling?
Sample:MultiLine Labeling
How to create a weather line style?
Sample:Weather Line Style
Sample:Isolines
map_suite_web_edition_faq_styles.1441778943.txt.gz · Last modified: 2015/09/09 06:09 by admin
