map_suite_web_edition_faq_miscellaneous
Map_Suite_Web_Edition_FAQ_Miscellaneous
How do I save or serialize my objects once I have created them?
Sample: Serialize To Xml
This sample shows you how to serialize objects in Map Suite to XML and then deserialze them back to objects. This is usefully in many GIS mapping application to save the state of styles, layers, projections or just about anything. The XML is readable and well formatted, great for working with in you GIS application.
How do I generate source code from objects once I have created them?
Sample: Code Generator
This sample shows you how to generate source code calls from Map Suite objects. Imagine that you have a Layer that has been styled a particular way and uses a certain projection. Once the object is created you can pass it to the code generator and it will create source code to re-create the model passed in. This is very helpful especially in GIS applications where users define things through a custom UI but then want to leverage that in code.
How do I add sub menu to the built-in context menu?
Sample:Context Menu with Sub Menu
Based on a discussion forum request, today's web project shows you how to add sub menus to ContextMenu. This is a built-in function in all of the most recent daily builds of Map Suite, which you can download from the ThinkGeo Customer Portal. This project also demonstrates how to enable the ContextMenu's auto wrap feature when you click on the edges of the map.
How do I export the current extent to a geo-referenced bitmap?
Sample:Current Extent to Bitmap
How do I create a custom scale bar that is accurate in another projection?
Sample:Custom Scale Bar
How do I use the map with the MVC framework?
Sample:Use Map with MVC Framework
How can I draw an exception instead of being thrown during drawing?
Sample:Draw Custom Exception
How do I convert the current extent of a raster layer to a bitmap?
Sample:Raster Layer to Bitmap
How do I have a map in an MDI form?
Sample:MDI Form
Map Suite Web Edition Web GIS Desktop GIS GIS .NET
map_suite_web_edition_faq_miscellaneous.1440040124.txt.gz · Last modified: 2015/09/09 06:06 (external edit)
