map_suite_web_edition_faq_general_questions
Map_Suite_Web_Edition_FAQ_General_Questions
Do I have control over how the map looks and fits into my application?
Yes, absolutely. Map Suite Web Edition is an ASP.NET control, so you can easily integrate it into your application just like any other control from the Toolbox. We expose a large amount of APIs that allow you to customize every aspect of the map and the user interface so that they fit in with the look and feel of your application.
What other software is required to work with Map Suite Web Edition?
To work with Map Suite Web Edition, you will need a copy of Microsoft Visual Studio or Visual Studio Express to build the code for your custom application.
Does Map Suite Web Edition require any third party controls to be downloaded and installed on the client browser?
No. Map Suite Web Edition utilizes JavaScript to handle all browser-side operations, so no third party ActiveX controls are needed.
What type of map data does Map Suite Web Edition Support?
Map Suite Web Edition lets you use virtually any map dataset of your choosing. If you have your own map data, you can utilize it. Alternatively, you can utilize our Map Suite World Map Kit extension, Google Maps, Virtual Earth or Yahoo Maps — just to name a few options.
Map Suite Web Edition comes with native support for the most popular vector and raster file formats, and includes a free extension that enables support for more than a dozen more vector formats and more than 80 raster formats. If you have spatial data or imagery, chances are you can use it with Map Suite. Check our Developer Blog for the master list of data formats that Map Suite currently supports.
How big of a learning curve is there to using Map Suite Web Edition?
Map Suite Web Edition was designed to be easy to understand and easy to use. While mapping/GIS controls typically have a larger learning curve than other simpler controls like grids or charts, we feel Map Suite has taken the complexity out of mapping and allows you to develop your application in days or weeks instead of months or years.
Where do I go if I need help with Map Suite Web Edition?
We have a very active Developer Community discussion forum, a large number of “How Do I?” sample applications with complete source code, and we also offer professional services if you need to talk with a developer one-on-one.
What is the difference between Map Suite Web Edition and Map Suite Services Edition?
Map Suite Web Edition comes with built-in functionality to construct a robust user interface in a web environment, while the Services Edition is designed for back-end applications like web services, Windows services and console applications where no user interface elements are needed.
Yes. We offer a number of Map Suite add-ons that extend the functionality and map coverage of your application, including the World Map Kit dataset plugin, and the Routing Extension that generates routes, turn-by-turn directions and more. Additionally, check out the Map Suite Code Community for an ever-expanding number of add-on projects that bring new features and ideas to your Map Suite projects - there's something new each week.
I'm seeing an "Unlicensed for Runtime" watermark on the map after I deploy my web application to IIS.?
You are seeing this message because the Production Web Server license is not installed on your server. There are two kinds of licenses for Map Suite Web Edition:
#The Development License is for a development environment. It allows you to develop your application within Visual Studio. #The Production Web Server License is for a production environment. It removes the “Unlicensed” watermark in runtime. To install the Production Web Server License, you need to run the Map Suite Web Edition Server Preparation Tool that can be found in the My Downloads section of the Customer Portal. Easy-to-follow installation instructions are included with the tool.
Map Suite Web Edition Web GIS ASP.NET GIS .NET
map_suite_web_edition_faq_general_questions.1440040124.txt.gz · Last modified: 2015/09/09 05:51 (external edit)
