map_suite_web_edition_background_maps_google_bing_etc._samples
Map Suite Web Edition Background Maps (Google, Bing, etc.) Samples
ArcGISServerRestOverlay
In this web-based project, we'll demonstrate the new ArcGISServerRestOverlay released with Map Suite 5.0 WebEdition. This overlay gives developers a simple and powerful tool to access their maps that reside on ArcGIS Server. This new overlay utilizes the ArcGIS Server REST API.
You can also check out the sample video to see the ArcGISServerRestOverlay in action.
Custom Map with Google Labels
GPS to Google Map(Web)
Great Circle with Google Map
Mini map with Google Map
OpenStreetMap
Shapefile to Google Map
Street View and Traffic
In this web-based project, we demonstrate using Google's Street View and Traffic overlays. This functionality is new to the WebEdition and is available with any daily build version 5.5.134.0 or higher. Developers can choose to enable this new functionality on either the server side or with client-side javascript.
map_suite_web_edition_background_maps_google_bing_etc._samples.1442558129.txt.gz · Last modified: 2015/09/18 06:35 by admin
