View Source |
Applies To: MVC \ Web
In this web-based project, we'll demonstrate the new ArcGISServerRestOverlay released with Map Suite 5.0 WebEdition. This overlay gives developers a simple and powerful tool to access their maps that reside on ArcGIS Server. This new overlay utilizes the ArcGIS Server REST API.
You can also check out the sample video to see the ArcGISServerRestOverlay in action.
View Source |
Applies To: Web
View Source |
Applies To: Web \ Silverlight
View Source |
View Source |
View Source |
View Source |
View Source |
Applies To: Web
In this web-based project, we demonstrate using Google's Street View and Traffic overlays. This functionality is new to the WebEdition and is available with any daily build version 5.5.134.0 or higher. Developers can choose to enable this new functionality on either the server side or with client-side javascript.
