The purpose of this guide is to show you how to upload your Web Edition Sample to Azure Server, and at the same time install the Web Server Edition to remove the watermark after deployment. It is using 3 key files( one cmd , one exe and one msi). Web Server Edition serial number needs to be upgraded in the cmd file to pass the online validation.
This guide works with Map Suite 7.0 Web Edition. If you are using 7.0.0.0 assemblies you can directly use the attached tools. If you are using a newer version please replace the “Setup Unmanaged Dependencies 7.0.0.0.msi” and update the corresponding script in MapSuiteWebServerAzureInstaller.cmd.
filelinkDownload This Sample ( 22.65 MB)
Map1.MapBackground.BackgroundBrush = new GeoSolidBrush(GeoColor.FromHtml("#E5E3DF")); Map1.CurrentExtent = new RectangleShape(-131.22, 55.05, -54.03, 16.91); Map1.MapUnit = GeographyUnit.DecimalDegree; Map1.MapTools.PanZoomBar.Enabled = true; Map1.MapTools.MouseCoordinate.Enabled = true; WorldMapKitWmsWebOverlay worldMapKitOverlay = new WorldMapKitWmsWebOverlay(); ShapeFileFeatureLayer layer = new ShapeFileFeatureLayer(Server.MapPath("SampleData/cities_a.shp")); layer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.Capital1; layer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; InMemoryFeatureLayer imfl = new InMemoryFeatureLayer(); imfl.InternalFeatures.Add(new Feature(Map1.CurrentExtent.GetCenterPoint())); imfl.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.Capital1; imfl.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; LayerOverlay overlay = new LayerOverlay(); overlay.Layers.Add(layer); Map1.CustomOverlays.Add(overlay);
<Startup><Task commandLine=“MapSuiteWebServerAzureInstaller.cmd” executionContext=“elevated” taskType=“simple”></Task></Startup>
