Map Suite provides a comprehensive set of styles which will cover most mapping requirements. Read more about the Map Suite Style Guide under Style Guide. This basic styling sample for Map Suite WebAPI Edition will provide you with an introduction to the some of the available styles, including PointStyle, LineStyle, AreaStyle, CompoundStyles, and PredefinedStyles. Styles use pens, brushes and fonts to render your data on canvas. These can be used together to achieve desired effects.
In this sample we render the data with predefined styles.
Area style :basemap and water
Line style :highway
Point style :poi (points of interest)
Render areas such as polygons, ellipses and rectangles. In this sample we render three areas. Area style has fill solid brush and Outline pen. The brush has color and alpha. The pen has width also include color and alpha. We can change their values.
Renders lines and multilines. In this sample we render major roads in Frisco. Line style has center pen, inner pen, and outer pen. We can use different colors to express different traffic conditions.
Renders point with custom images. In this sample we render high schools in Frisco. We set the point type to bitmap, and give the path of image, but you can use custom image.
Allows you to render point with predefined symbol, including circle, square, triangle, cross, diamond, diamond2, star, star2. In this sample we using a triangle to mark the ThinkGeo headquarters. This is a great option if your don't have any custom images.
Allows you to render points based on a font. In this sample all hospitals in Frisco are rendered with an “H”.
Styles can be assigned to ZoomLevels. In this sample there are four sets of styles, as you zoom in/out you are able to view the the different styles based on your current zoomlevels.
