The Map Suite Spatial Data Extension QuickStart Guide will guide you through the process of creating a simple spatially aware application using the ArcSDE® data service and help you become familiar with the Map Suite Spatial Data Extension. Please note that you will need to install ArcGIS Server version 9.3 from ESRI® as there are some binaries included that the Map Suite Spatial Data Extension relies upon.
This QuickStart will guide you through the process of creating a simple spatially aware application using the ArcSDE® data service and help you become familiar with the Map Suite Spatial Data Extension. Like any new software, there is some learning to be done.
NOTE: The beta version of the Spatial Data Extension is intended for testing and is currently supplied as an Evaluation Edition that will expire 60 days after installation.
ArcSDE (Spatial Database Engine) is server software produced by ESRI® that spatially enables a Relational Database Management System, and the spatial data may be used as part of a Geodatabase. Currently the Map Suite Spatial Data Extension only supports ArcSDE 9.3 and only works on 32-bit operating systems (it does not support 64-bit Windows).
a. MapSuiteSpatialDataExtension.dll, located in the installation folder
b. MapSuiteSpatialDataExtension folder (located in the Windows\system32 folder), containing the following files:
Three files (“pe.dll”, “sde.dll”, and “sg.dll”) are found in your ArcSDE Server 9.3 installation folder. The rest of the files are from FDO 3.4.1 RC2 (http://fdo.osgeo.org/content/fdo-341-downloads). The following files have been modified by ThinkGeo:
If you would like to request the source code that includes the changes ThinkGeo has made to FDO, please contact us.
Let's start with a new Windows Forms project in the Visual Studio.NET 2008 IDE. You can choose .NET Framework 4.5, 4.0, 3.5, 3.0 or 2.0. Three additional steps also need to be performed as described below:
Note: If you are using the Map Suite Spatial Data Extension version 7.0.0.0 or later, you also need to add “WindowsBase.dll” to the references. WindowsBase can be found on the .NET tab of the Add Reference dialog. If you don't do this, you will get the following error when you compile the project:
“The type 'System.Collections.Specialized.INotifyCollectionChanged' is defined in an assembly that is not referenced. You must add a reference to assembly 'WindowsBase, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'.”
(Note: We are using Map Suite Services Edition for the purposes of this example. If you have installed a different edition of Map Suite, the steps here will be similar.)
:1. How to display a map using ArcSDE data: ::a. Add the “MapSuiteSpatialDataExtension.dll” reference to your project. ::b. Add the following code:
<source lang=“csharp”>
private void Sample_Load(object sender, EventArgs e)
string serverIP = "192.168.0.165";
string port = "5151";
string username = "username";
string password = "password";
string datastore = "master"; <nowiki>//</nowiki> Case-Sensitive.
string idColumnName = "OBJECTID"; <nowiki>//</nowiki> Case-Sensitive.
string schemaName = "master_dbo"; <nowiki>//</nowiki> Case-Sensitive.
string featureClassName = "Tablename"; <nowiki>//</nowiki> Case-Sensitive.
string geometryColumnName = "Shape"; <nowiki>//</nowiki> Case-Sensitive.
ArcSdeFeatureLayer layer = new ArcSdeFeatureLayer(serverIP, port, username, password, datastore, idColumnName, schemaName, featureClassName, geometryColumnName);
layer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
layer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.Country1;
MapEngine engine = new MapEngine();
engine.CurrentExtent = new RectangleShape(-180, 90, 180, -90);
engine.StaticLayers.Add(layer);
RefreshMap(engine);
private void RefreshMap(MapEngine engine)
Bitmap bmp = new Bitmap(pictureBox1.Width, pictureBox1.Height);
engine.OpenAllLayers();
engine.DrawStaticLayers(bmp, GeographyUnit.DecimalDegree);
pictureBox1.Image = bmp;
engine.CloseAllLayers();
</source>
:Notes:
:If you don't know the proper values of the SchemaName and FeatureClassName parameters, then you can set them to
String.Empty
and use some special functions to list the available SchemaNames and FeatureClassNames. For SchemaName, use the
layer.GetFeatureSchemaNames();
function to get a schema name list, from which you can choose a SchemaName. For FeatureClassName, use
layer.GetFeatureClassNamesBySchema(string featureSchemaName)
to get a feature class name list, from which you can choose a FeatureClassName. After performing these two steps, change the SchemaName and FeatureClassName parameters to the actual values.
:2. How to perform the ExecuteQuery operation for ArcSDE Server: ::a. Complete the same steps as shown in the “How to display a map using ArcSDE data” section above. ::b. Use
layer.Open();
to open the layer. ::c. Use
layer.QueryTools.ExecuteQuery(string sqlStatement);
to perform the execute query operation for ArcSDE Server.
:3. Because many properties for an ArcSDE Server are case sensitive, please be careful and always ensure that you are using the proper case. Issues with incorrect case are the most common cause of errors.
