article_rating In this article, we'll talk about how to deploy applications using Map Suite Spatial Date Extension.
Several Merge Modules are supplied to assist you in deploying all of our required dependencies. You can find then in the directory below. *\Developer Reference\Merge Module\MapSuiteEcwX64.msm *\Developer Reference\Merge Module\MapSuiteEcwX86.msm *\Developer Reference\Merge Module\MapSuiteFdoExtensionX86.msm *\Developer Reference\Merge Module\MapSuiteGeoTiffX64.msm *\Developer Reference\Merge Module\MapSuiteGeoTiffX86.msm *\Developer Reference\Merge Module\MapSuiteMrSidX64.msm *\Developer Reference\Merge Module\MapSuiteMrSidX86.msm *\Developer Reference\Merge Module\MapSuiteProj4ProjectionX64.msm *\Developer Reference\Merge Module\MapSuiteProj4ProjectionX86.msm *\Developer Reference\Merge Module\MapSuiteSpatialDataExtensionMergeModule.msm *\Developer Reference\Merge Module\VC_User_CRT71_RTL_X86_—.msm *\Developer Reference\Merge Module\VC_User_STL71_RTL_X86_—.msm Note:The main assemblies of MapSuiteCore.DLL ,MapSuiteSpatialDataExtension.DLL,NetTopologySuite.DLL,GeoAPI.dll are not included in the Merge Modules, your project should automatically reference them and pull in these assemblies. MapSuiteGeoTiffX64.msm and MapSuiteGeoTiffX86.msm are not required if the GeoTiffRasterSource's LibraryType is ManagedLibTiff(By Default). MapSuiteProj4ProjectionX64.msm and MapSuiteProj4ProjectionX86.msm are not required if Proj4Projection's MemoryMode is ManagedProj4Projection(By Default).
There are a number of dependencies that are required for different functionality. Below is a list of DLLs and their usage.
Core Libraries *GeoAPI.dll *MapSuiteCore.dll *NetTopologySuite.dll
Libraries Required for Satellite Imagery in 32 bit system. (Must be in the SYSTEMROOT) *Map Suite 5.5\MapSuiteGeoRasterx86\lti_dsdk_dll.dll *Map Suite 5.5\MapSuiteGeoRasterx86\MapSuiteEcwX86.DLL *Map Suite 5.5\MapSuiteGeoRasterx86\MapSuiteGeoRasterX86.dll *Map Suite 5.5\MapSuiteGeoRasterx86\MapSuiteMrSidsX86.DLL *msvcp71.dll *msvcr71.dll *Map Suite 5.5\MapSuiteGeoRasterx86\NCScnet.dll *Map Suite 5.5\MapSuiteGeoRasterx86\NCSEcw.dll *Map Suite 5.5\MapSuiteGeoRasterx86\NCSUtil.dll
Libraries Required for Satellite Imagery in 64 bit system. (Must be in the SYSTEMROOT) *Map Suite 5.5\MapSuiteGeoRasterx64\lti_dsdk_dll.dll *Map Suite 5.5\MapSuiteGeoRasterx64\MapSuiteEcwX64.DLL *Map Suite 5.5\MapSuiteGeoRasterx64\MapSuiteGeoRasterX64.dll *Map Suite 5.5\MapSuiteGeoRasterx64\MapSuiteMrSidsX64.DLL *msvcp71.dll *msvcr71.dll *Map Suite 5.5\MapSuiteGeoRasterx64\NCScnet.dll *Map Suite 5.5\MapSuiteGeoRasterx64\NCSEcw.dll *Map Suite 5.5\MapSuiteGeoRasterx64\NCSUtil.dll
Libraries for TiffWrapper Support.(Must be in the SYSTEMROOT) *Map Suite 5.5\TiffWrapperX86.dll *Map Suite 5.5\TiffWrapperX86.dll
Libraries for Projection Support. (Must be in the SYSTEMROOT) *Map Suite 5.5\MapSuiteProjectionX64.dll *Map Suite 5.5\MapSuiteProjectionX86.dll *Map Suite 5.5\Proj4ExtensionX64.dll *Map Suite 5.5\Proj4ExtensionX86.dll
Libaries for Fdo Data Feature Support.(The whole folder must be copied to the SYSTEMROOT\) *Map Suite 5.5\MapSuiteFdoExtensionX86\
Note
In order to use the Map Suite Spatial Data Extension, you must have ESRI® ArcSDE® Server 9.3 installed.
Map Suite Spatial Data Extension requires a 32-bit Windows OS(64-bit Windows is not compatible).
