View Source |
Applies To: Silverlight
You can also check out Part 1 and Part 2 of the video which provides a brief summary of this sample.
View Source |
We have extended the reach of our Silverlight client to utilize the Out-Of-Browser (OOB) feature. This allows you to launch Silverlight applications either disconnected or connected without the browser as the container.
Important Points:
1. To run application in out-of-browser mode, you have to right-click the project and show the “Project Properties” window, then select “Enable running application out of the browser”. You must also click the button labeled “Out-of-Browser Settings…” and make sure the item “Require elevated trust when running outside the browser” is selected.
2. To make sure the ServerLayerOverlay works properly in out-of-browser mode, the property “ConnectorHost” URL of the ServerLayerOverlay must be set. This represents the URL of the page that is hosting the SilverlightMapConnector.
View Source |
View Source |
View Source |
View Source |
For more details including a list of topology cases that you can test, see this article or watch the [[http://youtu.be/IuLGTRsVtQc|video overview]]
View Source |
View Source |
