map_suite_silverlight_edition_miscellaneous_samples
Map Suite Silverlight Edition Miscellaneous Samples
Best Practices - Silverlight Edition
Applies To: Silverlight
You can also check out [[Media:SilverlightEditionSample_ClientAndServerData_CS_110614_part1.mp4|Part 1]] and [[Media:SilverlightEditionSample_ClientAndServerData_CS_110614_part2.mp4|Part 2]] of the video which provides a brief summary of this sample.
Out of Browser Support
We have extended the reach of our Silverlight client to utilize the Out-Of-Browser (OOB) feature. This allows you to launch Silverlight applications either disconnected or connected without the browser as the container.
Important Points:
1. To run application in out-of-browser mode, you have to right-click the project and show the “Project Properties” window, then select “Enable running application out of the browser”. You must also click the button labeled “Out-of-Browser Settings…” and make sure the item “Require elevated trust when running outside the browser” is selected.
2. To make sure the ServerLayerOverlay works properly in out-of-browser mode, the property “ConnectorHost” URL of the ServerLayerOverlay must be set. This represents the URL of the page that is hosting the SilverlightMapConnector.
Custom Scale Bar
Draw Custom Exception
MDI Form
Topology Validation
For more details including a list of topology cases that you can test, see this article or watch the [[http://youtu.be/IuLGTRsVtQc|video overview]]
Use Map with MVC Framework
Use Progress Bar
Map Suite Explorer (ServiceEdition)
Tile Cache Generator
<div sample_otherlinks> [
map_suite_silverlight_edition_miscellaneous_samples.1441783994.txt.gz · Last modified: 2015/09/09 07:33 by admin
