map_suite_silverlight_edition_features_bug_fixes_change_log
Map Suite Silverlight Edition Features & Bug Fixes Change Log
Version 9.0.0.0
Release date: 06/24/2015
ThinkGeo.MapSuite.SilverlightEdition Namespace:
  • Upgraded the SilverlightEdition from Silverlight 4.0 to Silverlight 5.0
  • Added Leader Lines.
  • Added Archery Indexing for KML feature layers.
Version 8.0.0.0
Release date: 06/06/2014
  • Fixed a bug where the force refresh of WmsOverlay doesn't request the server if applyed cache
  • Fixed a bug where the mouse coordinate is incorrect in some places
Version 7.0.0.0
Release date: 06/03/2013
  • Fixed a bug that the TransitionEffect.Stretching doesn't stretch the map
  • Fixed a bug that the strong name is incorrect in build package
  • Fixed a bug that a strange exception will be thrown is the key is empty in BingMapsOverlay in Silverlight Edition
  • Improved the static Maps API for GoogleOverlay
Version 6.0.0.0
Release date: 12/31/2011
  • Improved the Bing Maps performance by switching the Bing Maps Service from SOAP to REST.
  • Fixed an issue where WMSOverlay and LayerOverlay has an overlap while panning the map.
  • Fixed the issue where the overlay is always flicking while panning the map
  • Fixed an issue where HaloPen doesn't properly displayed.
  • Fixed an issue where a blue area appears to the left and right of the map after panning.
  • Added the support of Out-Of-Browser.
Version 5.5.0.49
  • Fixed an issue that the google overlay does not synchronize with wms overlay when panning.
  • Fixed an issue where the google overlay does not synchronize with LayerOverlay when panning fast.
Version 5.5.0.0
Release date: 11/14/2011
  • Fixed an issue that BingMapsOverlay and OpenStreetMapOverlay doesn't match the WMSOverlay and ServerLayerOverlay in Google Projection.
  • Fixed an issue where the control points of editOverlay don't display properly
  • Fixed an issue where the map is dislocated when panning the markers
  • Fixed an issue where the popup disappears when the mouse is moved from the marker to the popup.
  • Added the IsoLine Support.
Version 5.0.0.55
Release date: 7/7/2011
  • Fixed a bug where IsStreatchEffectDisabled behavior confused customers
  • Fixed a bug where PointStyle drawn image regardless the image size
  • Fixed a bug where image size setting had no effect in PointStyle
  • Fixed a bug where the panning is pretty slow while using shape files on client side
  • Fixed a bug where panning is slow with directional pan arrows
  • Enhanced PointStyle.City default style
  • Fixed a bug where the EllipseShape with radius distance was not displayed properly
Version 5.0.0.0
Release date: 5/16/2011
  • Fixed a bug where it threw OutOfRangeException when editing.
  • Fixed the bug where the GoogleOverlay doesn't match WMSOverlay or LayerOverlay using projection 900913.
  • Fixed a bug where GoogleOverlay doesn't updated after a mouse pan.
  • Fixed a bug there the constuctor of GoogleMapsOverlay was incorrect.
  • Obsoleted ClientZoomLevelScales property and SyncZoomLevelScales method, but added ZoomLevelSet proeperty instead.
  • Integrated the Proj4 projection library.
  • Enhanced the implementation of the WMS client which using the GetCapabilities requests.
  • Added client side Bing Maps support.
ThinkGeo.MapSuite.SilverlightCore Namespace:
  • Added Simplify method to AreaBaseShape.
  • Added DrawingException method to layer to provide a custom way for dealing with exceptions.
  • Added PenBrushDrawingOrder enumeration to AreaStyle.
  • Added BuildIndex method to InMemoryFeatureLayer to build an inmemory spatial index.
  • Added BuildIndexFile method to ShapeFileFeatureLayer.
  • Added StreamLoading event to ShapeFileFeatureLayer.
  • Improved the GeoCollection Class with adding some collection related methods(such as MoveUp) and events(such as Added).
  • Added GeometryCollectionShape support.
  • Added Simplify, Union and GetIntersection methods to LineBaseShape.
  • Updated the GeoCanvas.Draw methods by adding DrawingLevel as a parameter.
  • Added Tag to BaseShape and Feature.
  • Added Wrapping Support to FeatureLayer.
  • Added 3 new styles: GradientStyle, DotDensityStyle and QualityFamilyAreaStyle
  • Added DrawingProgressChanged event to FeatureSource
  • Added HSV (Hue/Saturation/Luminance) support to GeoColor.
  • Added a new brush: GeoTextureBrush
  • Added GetFeaturesByColumnValue method and GetFeaturesNearestTo method to FeatureSource
  • Added LabelingLocationModeForPolygon to PositionStyle to provide control for Polygon's labeling location.
  • Added DrawingLineCap enumeration
  • Marked Serializable for GeoTiffRasterLayer, HeatLayer, GraticuleAdornmentLayer and HeatStyle.
  • Removed the Obsolete APIs.
Version 4.5.0.0
Release date: 11/01/2010
  • Fixed issue that the text rotate is not right sometimes in LabelRotateAMarker sample.
  • Fixed lots of new warnings with FXCop
  • Added OpenStreetMap Support
  • Added TiledWMSOverlay
  • Updated the platform to Silverlight4.0
  • Added ClusterPointStyle
Version 4.0.40.0
Release date: 6/15/2010
  • Updated assembly version to 4.0.0.0; included strong-named and weak-named assemblies. Please see the latest post in the Developer Blog for full details.
ThinkGeo.MapSuite.Silverlight Namespace:
  • Improved performance of drawing geography features from MS SQL Server 2008.
  • Fixed issue where the map would be misplaced after dropping the mouse when panning the GoogleOverlay.
  • Fixed issue with the ScaleTo API in BaseShape when called by a Rectangle Shape.
  • Fixed issue where an exception would be thrown when calling BuildIndex in a Turkish enviroment.
  • Fixed issue when using the UpdateColumnName API in DBF module.
  • Fixed issue involving use of Chinese fonts
  • Fixed a rounding bug in the GetPointOnALine API of LineShape.
  • Some minor API changes. See the API change log for complete details.
Version 4.0.0
Release date: 5/1/2010
  • Many core enhancements and additions as itemized here.
  • Added Blend3 support.
  • Added Visual Studio 2010 support.
  • Added Google Static API v2 support.
  • Added “Filter” support for GetFeaturesByColumnValue of WFSFeatureLayer.
  • Added support for Bing Maps in multithreaded mode.
  • Improved support for IIS7 in Integrated Mode.
  • Fixed issue with panning and zooming stretch effect.
  • Fixed issue with an exception when setting both DefaultStyle and CustomStyle.
  • Fixed issue where a marker click event works incorrectly when multiple markers are added.
  • Fixed issue where setting Marker.ImageRotationAngle has no effect.
  • Fixed a bug where a marker cannot rotate during constructing.
  • Fixed ArgumentOutOfRangeException in ExtentHelper.ToScreenCoordinate.
  • Fixed issue where using HaloPen has no effect.
  • Fixed issue where the font size of GeoFont doesn't affect the rendering.
  • Fixed issue where a single tiled GoogleOverlay doesn't refresh when mouse wheel zooming.
  • Fixed issue where the transparent background of the PanZoomBar prevents clicking event on the map.
  • Updated the API documentation.
  • Some API changes as detailed in the API change log.
  • Added additional helper methods to the GeoCollection class.
  • Added better support for labeling with Asian characters.
  • Added support for Google Static Maps API v2.
  • Added simple support for Yahoo Maps.
  • Added support for heat map layers.
  • Added support for 100% managed proj Projection Library.
  • Added direct support for Map Shapes.
  • Added API to modify the column name in ShapeFileFeatureSource and ShapeFileFeatureLayer.
  • Added new API BuildIndex for MultipleShapeFileFeatureLayer
  • Included GraticuleLineLayer support and a sample application for it.
  • Enhanced the MultiShapeFileFeaturesLayer class to allow you to use files in multiple folders.
  • Enhanced the distance measuring method to use the Haversine formula.
  • Improved GeoCache performance.
  • Updated the PostgreSQL Assembly versions.
  • Exposed the DBaseFile class library.
  • Exposed the disk-based RTree Spatial Index.
  • Split up the Map Suite MergeModule into smaller and more manageable pieces.
  • Fixed issue where GetCenterPoint using NTS would return an invalid value when the polygon's width and height is 0.
  • Fixed issue regarding GetBoundingBox of GroupLayer.
  • Fixed issue where GetAllColumns also returns the Geometries column.
  • Many API additions. See the API change log for complete details.
Version 3.1.299
Release date: 11/16/2009
  • Concluded public beta and moved to final release.
  • Added projection property in the WorldMapKitWmsSilverlightOverlay.
  • Added documentation for InteractiveOverlay.
  • Fixed issue where the marker click event did not work correctly when adding two markers.
  • Fixed issue with outdated cached images when track zooming in.
  • Fixed issue where SaveToProjection is incorrect for some data.
  • Fixed issue with the DecimalDegreesHelper API GetDecimalDegreeFromDegreesMinutesSeconds.
  • Fixed caculation issue in DecimalDegreeHelper.GetDistanceFromDecimalDegrees when passing particular data.
  • Fixed issue where an exception is thrown for TAB files when the column name starts with an underscore(_).
map_suite_silverlight_edition_features_bug_fixes_change_log.1441786888.txt.gz · Last modified: 2015/09/09 08:21 by admin
