map_suite_services_edition_vehicle_tracking_samples
Map_Suite_Services_Edition_Vehicle_Tracking_Samples
Centering and Rotating
Screenshot width=78Sample width=66Product Description
map_suite_services_edition_sample_centering_and_rotating.jpg View Source
C# Download
Need it in another language?
Services \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In the project “Centering On Moving Vehicle”, we learned how to have the map always centered on a moving vehicle. In this project, we go one step further and show how to have the map also rotating according to the direction of the moving vehicle. In this project, you will also see how to use the CompassAdornmentLayer that always indicates the north as the map rotates.
map_suite_services_edition_sample_centering_on_moving_vehicle.jpg View Source
C# Download
Services \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ A commonly requested feature when tracking a vehicle for GPS application is to have the map centered on a vehicle as it moves. Implementing this is fairly easy with Map suite using the CenterAt API. In this project, you will see this feature in action with a vehicle represented by a vehicle icon being always the center of the extent of the map. You can also take advantage of this project to learn some other techniques related to GPS such as reading GPS data from a text file and applying a rotation angle to show the direction.
Chemical Plume
map_suite_services_edition_sample_chemical_plume.jpg View Source
C# Download
Services \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In this project, we show how simple it is to display and do spatial analysis with chemical plumes.
Filter Radar Image
map_suite_services_edition_sample_filter_radar_image.jpg View Source
C# Download
Services \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ NOAA (National Oceanic and Atmospheric Administration) makes available for the public Radar images http://radar.weather.gov/ridge/Conus/RadarImg/
Rotated Image Style
map_suite_services_edition_sample_rotated_image_style.jpg View Source
C# Download
Services \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ This project shows how to use an icon to rotate it according to the direction of some GPS readings. An InMemoryFeatureLayer is used with various Features representing vehicles. For representing the symbol a Custom Style is created inheriting from Style. Notice that the Custom Style overrides the methods DrawCore and GetColumnNamesCore. You will also see how to update the X and Y value of the PointShape making up each feature. This project is based on the Servicess edition, I recommend also to look at the project Vehicle Direction which is a Desktop App. The difference is in the use of the Layers and the drawing techniques to update the position and symbol of the features.
Snap GPS to Street
map_suite_services_edition_sample_snap_gps_to_street.jpg View Source
C# Download
Services \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In this sample we are going to handle the common case of snapping a point to a set of features in a layer. The common case for this is snapping real-time GPS points to road layers. GPS has an error factor and it's nice to display vehicles on a map snapped to the roads they are on. It can also be used for a number of other different cases as well, such as finding not just the road position but the road name. You may display or store the road name for the trip in your database.
map_suite_services_edition_vehicle_tracking_samples.1440040124.txt.gz · Last modified: 2015/09/08 02:58 (external edit)
