map_suite_services_edition_spatial_functions_samples
Map Suite Services Edition Spatial Functions Samples
Clipping
Clipping On Point Layer
Convex Hull
Correcting Nodes
Create Polygon Programatically
Dissolve on Shapefile
Draw a Pie shape
Dynamic Segmentation
Get Feature Clicked On With Projection
Identify Point with Icon
Inner Ring Containment
Intersecting Multi Polygon
Intersecting Two Layers
Merge Line Layers
Merge Point Layers
Merging Layers
Multi Ring Buffering
LEAD Technologies Inc. V1.01
Negative Buffering
Offset Point at Right Angle
Register Shape
Remove LineShape
Spatial Join
Split Polygon
Split Polygon Based On Grid
From the Performance Guide:
Split Polygon Dynamically into Grids based on the Area
This utility was designed to create a “Dynamic Grid” based on the area of the shape, for example, grids in Russia should be bigger than the grids in France. Compared with the fixed size grid in sample http://wiki.thinkgeo.com/wiki/map_suite_services_edition_all_samples#split_polygon_based_on_grid , it’s more efficient and has a better performance when drawing it.
Sweep Angle
Splitting Polygons with a Line
map_suite_services_edition_spatial_functions_samples.1475608967.txt.gz · Last modified: 2016/10/04 19:22 by benbai
