From the Performance Guide:
This utility was designed to create a “Dynamic Grid” based on the area of the shape, for example, grids in Russia should be bigger than the grids in France. Compared with the fixed size grid in sample http://wiki.thinkgeo.com/wiki/map_suite_services_edition_all_samples#split_polygon_based_on_grid , it’s more efficient and has a better performance when drawing it.
