View Source |
View Source |
View Source |
View Source |
View Source |
View Source |
View Source |
View Source |
codesamples
View Source |
View Source |
View Source |
View Source |
View Source |
View Source |
codesamples
View Source |
View Source |
View Source |
If you have many files of the same type and representing the same type of features, Map Suite offers an API for building a multi index and treating all the various files as one layer. You can see this Discussion Forum post for more info on that: http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/5921/afv/topic/Default.aspx
View Source |
View Source |
View Source |
View Source |
View Source |
View Source |
View Source |
View Source |
This utility was designed to grid high point-count polygons to aid in faster rendering. It is one of the utilities used in the Performance Guide section of the wiki and is also featured in a [[http://download.thinkgeo.com/Videos/Wiki/IncreasingPolygonPerformance.wmv|performance learning video]].
From the Performance Guide:
View Source |
