map_suite_services_edition_spatial_functions_samples
Map Suite Services Edition Spatial Functions Samples
Clipping
Clipping On Point Layer
Convex Hull
Correcting Nodes
Create Polygon Programatically
Dissolve on Shapefile
codesamples
Draw a Pie shape
Dynamic Segmentation
codesamples
Get Feature Clicked On With Projection
Identify Point with Icon
Inner Ring Containment
Intersecting Multi Polygon
Intersecting Two Layers
Merge Line Layers
codesamples
Merge Point Layers
Merging Layers
If you have many files of the same type and representing the same type of features, Map Suite offers an API for building a multi index and treating all the various files as one layer. You can see this Discussion Forum post for more info on that: http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/5921/afv/topic/Default.aspx
Multi Ring Buffering
LEAD Technologies Inc. V1.01
Negative Buffering
Offset Point at Right Angle
Register Shape
Remove LineShape
Spatial Join
Split Polygon
Split Polygon Based On Grid
This utility was designed to grid high point-count polygons to aid in faster rendering. It is one of the utilities used in the Performance Guide section of the wiki and is also featured in a [[http://download.thinkgeo.com/Videos/Wiki/IncreasingPolygonPerformance.wmv|performance learning video]].
From the Performance Guide:
Sweep Angle
map_suite_services_edition_spatial_functions_samples.1441679300.txt.gz · Last modified: 2015/09/08 02:28 by admin
