map_suite_services_edition_miscellaneous_samples
Map Suite Services Edition Miscellaneous Samples
Map Suite Explorer (ServiceEdition)
Tile Cache Generator
This video will show you how to use the Map Suite Tile Cache Generator utility to generate tile caches based on your own layers. Pre-generating tiles based on your data allows you to display the data faster than rending it from vector graphics files. It also allows you to protect your vector data by providing just the raster tiles for display purposes only. In the past, pre-generating tiles required customers to build the process from scratch which was time consuming and often inefficient. With the Tile Cache Generator utility, we have packaged many of our best practices along with the source code, allowing you to tweak the process to your specific situation.
TinyGeo File Format Sample and Converter
This project provides a sample of how to use the new TinyGeo file format as well as provides an easy to use converter tool for shapefiles. The goal of the TinyGeo file format was to provide our customers with a highly compressed, read only, secure, and easily distributable data file that they could use to disseminate spatial data to their customers.
Note:This is a new beta feature of Map Suite 6.0 and only works with Map Suite developer build 5.5.36.0 or later.
Serialize To Xml
This sample shows you how to serialize objects in Map Suite to XML and then deserialze them back to objects. This is usefully in many GIS mapping application to save the state of styles, layers, projections or just about anything. The XML is readable and well formatted, great for working with in you GIS application.
Code Generator
This sample shows you how to generate source code calls from Map Suite objects. Imagine that you have a Layer that has been styled a particular way and uses a certain projection. Once the object is created you can pass it to the code generator and it will create source code to re-create the model passed in. This is very helpful especially in GIS applications where users define things through a custom UI but then want to leverage that in code.
Current Extent to Bitmap
Generate EMF using GraphicsGeoCanvas
This sample shows how you can generate an EMF file using GraphicsGeoCanvas, which is a custom GeoCanvas with the source available in the attached sample. Not just EMF in fact, we can draw on any passed Graphics object which can be a lot of formats. This sample works with 6.0.121.0/6.0.0.121 or later.
Raster Layer to Bitmap
Show A Legend
In today’s project we learn how to display a simple legend using the new and improved LegendAdornmentLayer. The improved LegendAdornmentLayer is new to the MapSuite 5.0 release and provides an easy to use api for creating legend adornments. The LegendAdornmentLayer is part of MapSuite.Core which gives all MapSuite products access to this powerful new feature.
ShapeFile to WkbFile Converter
This is a utility that converts data from Shapefile to Wkbfile. WKBfile may be a good option for rendering performance.
Geocoder Data Reducer
The Geocoder Data Reducer is a utility that allows you to create a new smaller geocoder index for specific states in the United States. You simply specify the directory of ThinkGeo full Geocoder Index files, select the states you want to reduce it to, the output folder, and the utility will create the new reduced index. Depending on the state the process may take up to a couple of hours to process.
COGO
COGO, an acronym for coordinate geometry, refers to a data conversion process in which a digital map is constructed from written descriptions, such as legal descriptions of land parcel boundaries. These descriptions often contain information about line length and direction, and point locations, all relative to the locations of certain key features such as geodetic control points, survey monuments, previously COGOed survey lines, etc. Some basic types of elements of COGO are points, spirals, lines and horizontal curves (circular arcs). More complex elements can be developed such as alignments or chains which are made up of a combination of points, curves or spirals.
map_suite_services_edition_miscellaneous_samples.1459329252.txt.gz · Last modified: 2016/03/30 09:14 by tgwikiupdate
