map_suite_services_edition_features_bug_fixes_change_log
Map Suite Services Edition Features & Bug Fixes Change Log
Version 9.0.0.0
Release date: 06/24/2015
  • Fixed a bug that the deployed version of WebEddition, MvcEdition, SilverlightEdition and WmsEdition runs into “Unlicensed for runtime”.
  • Fixed a bug where the MagneticDeclinationAdornmentLayer runs into memory issue.
  • Added Leader Lines.
Version 8.0.0.160
Release date: 11/17/2014
  • Fixed a bug where it runs into exception if the readed KML file includes the bool value.
Version 8.0.0.0
Release date: 06/06/2014
Version 7.0.0.0
Release date: 06/03/2013
  • Added the ClearCache method to MapPrinterLayer to delete the cache image
  • Added the spatial index status cache for MsSql2008FeatureSource
  • Added support of the FileGeoDatabase
  • Added support off write white paper on Printing
  • Added support of the GRD/GRI grid format
Version 6.0.0.0
Release date: 05/14/2012
Version 5.5.0.49
Release date: 12/31/2011
Version 5.5.0.0
Release date: 11/14/2011
  • Added the IsoLine Support.
Version 5.0.0.55
Release date: 7/7/2011
Version 5.0.0.0
Release date: 5/16/2011
  • Removed the Obsolete APIs.
Version 4.5.0.0
Release date: 11/01/2010
  • Added ClusterPointStyle
Version 4.0.40.0
Release date: 6/15/2010
  • Updated assembly version to 4.0.0.0; included strong-named and weak-named assemblies. Please see the latest post in the Developer Blog for full details.
  • Fixed issue with the ScaleTo API in BaseShape when called by a Rectangle Shape.
  • Fixed issue where an exception would be thrown when calling BuildIndex in a Turkish enviroment.
  • Fixed issue when using the UpdateColumnName API in DBF module.
  • Fixed issue involving use of Chinese fonts
  • Fixed a rounding bug in the GetPointOnALine API of LineShape.
  • Some minor API changes. See the API change log for complete details.
Version 4.0.0
Release date: 5/1/2010
  • Added additional helper methods to the GeoCollection class.
  • Added better support for labeling with Asian characters.
  • Added support for Google Static Maps API v2.
  • Added simple support for Yahoo Maps.
  • Added support for heat map layers.
  • Added support for 100% managed proj Projection Library.
  • Added direct support for Map Shapes.
  • Added API to modify the column name in ShapeFileFeatureSource and ShapeFileFeatureLayer.
  • Added new API BuildIndex for MultipleShapeFileFeatureLayer
  • Included GraticuleLineLayer support and a sample application for it.
  • Enhanced the MultiShapeFileFeaturesLayer class to allow you to use files in multiple folders.
  • Enhanced the distance measuring method to use the Haversine formula.
  • Improved GeoCache performance.
  • Updated the PostgreSQL Assembly versions.
  • Exposed the DBaseFile class library.
  • Exposed the disk-based RTree Spatial Index.
  • Split up the Map Suite MergeModule into smaller and more manageable pieces.
  • Fixed issue where GetCenterPoint using NTS would return an invalid value when the polygon's width and height is 0.
  • Fixed issue regarding GetBoundingBox of GroupLayer.
  • Fixed issue where GetAllColumns also returns the Geometries column.
  • Many API additions. See the API change log for complete details.
  • Updated the API documentation.
Version 3.1.299
Release date: 11/16/2009
  • Fixed issue where SaveToProjection is incorrect for some data.
  • Fixed issue with the DecimalDegreesHelper API GetDecimalDegreeFromDegreesMinutesSeconds.
  • Fixed caculation issue in DecimalDegreeHelper.GetDistanceFromDecimalDegrees when passing particular data.
  • Fixed issue where an exception is thrown for TAB files when the column name starts with an underscore(_).
Version 3.1.273
Release date: 10/22/2009
  • Added Haversine formula to calculate distance.
  • Added DrawException method to draw exceptions rather than throwing them in the Overlay and Layer.
  • Added IndexedInMemoryFeatureLayer Class.
  • Added ReadOnly logic to ClearCache and DeleteTile methods.
  • Added the schema supported in PostgreFeatureSource.
  • Added API overloads for GetFeaturesByColumnValue method.
  • Added API to detect the feature type in FeatureSource.
  • Added API BuildIndex in InMemoryFeatureLayer.
  • Enhanced the Sql2008FeatureSource, PostgreFeatureSource and OracleFeatureSource by adding one event ExecutingSqlStatement.
  • Extended the KeyColor from one color to an array of colors or a range of colors.
  • Fixed a memory leak when calling OpenAllLayers multiple times.
  • Fixed issue where ApplyUntilZoomLevel doesn't work right when using CustomZoomLevel.
  • Fixed OutofMemory exception issue in WFSFeatureSource.
  • Fixed issue where SaveToProjection in ShapeFileFeatureSource would throw an out of memory exception.
  • Fixed issue with the Stream_Loading event in ShapeFileFeatureSource.
  • Fixed issue with obfuscation in autobuild.
  • Fixed issue where the WMS cannot work properly when the network is unavailable.
  • Fixed issue where GetRandomColor always get the same color.
  • Fixed issue where CloneDeep of InMemoryFeatureSource does not work.
  • Fixed issue where InmemoryFeatureSource cannot be serialized correctly.
  • Fixed issue where you could not parse the parent layer in a WMS server.
  • Fixed issue where an OutOfMemory error occurs while drawing.
  • Fixed issue with support for Geography type data in MsSqlFeatureSource.
  • Fixed issue with the GetFeaturesInsideBoundingBox method of MultipleShapeFileFeatureSource.
  • Fixed issue where GetCenterPoint using NTS will return an invalid value when the polygon's width and height is 0.
  • Fixed issue regarding thrown exception ORA-00936: Missing Expression.
  • Fixed issue where GetPointOnALine returns the wrong value.
  • Fixed issue where GdiPlusRasterLayer has a black line in tile mode.
  • Fixed issue with the GetFeatureById API in WfsFeatureLayer.
  • Fixed very low performance issue with GetColumnsCore.
  • Fixed issue with missing tag information in InMemoryFeatureLayer.
  • Fixed non-serializable issue for WFSFeatureLayer.
  • Fixed issue where an exception was thrown when building an index for an empty shape file.
  • A number of API changes. See the API change log for complete details.
Version 3.1.182
Release date: 7/23/2009
  • Added some APIs for ScaleBar in order to implement the same functionality as in ScaleLine.
  • Fixed issue with setting a different DPI for canvas.
  • Fixed issue where the Matrix system did not consider the MapUnit.
  • Fixed issue where the OverrideMode did not work correctly for the ShapeFileFeatureLayer.SaveToProjection API.
  • Fixed issue where an exception would be thrown when using a MaskBrush for the ScaleBar.
  • Fixed issue where bool field cannot be updated in the DBF.
  • Fixed the Out of Memory Exception thrown when calling the ShapeFileFeatureLayer.SaveToProjection API on very large shape file data.
Version 3.1.124
Release date: 5/26/2009
  • Added an API to CheckForUnSupportedShapeTypes(string shapeFilePath).
  • Added support for a Polygon record that contains 0 parts.
  • Added an overload for BuildIndexFile.
  • Added ExecuteQuery support for Postgre.
  • Added property to show whether the assembly is the Full Version or Evaluation Version.
  • Added an overload to CreateShapeFile so that user can choose whether they want to override.
  • Added polygon simplification to AreaShapes.
  • Added line simplification to LineShapes.
  • Added obsolete to the AllowSpline property in text style.
  • Added GetFirstGeometryType in Postgre, Oracle and SQL layers.
  • Added “Simplify” sample application.
  • Added an overload to GetFeaturesNeareastTo with a distance limitation.
  • Added documentation for DashPattern.
  • Added ToGdiPlusColor method in GeoColor.
  • Added a way to build a spatial index based on another projection, not using a feature list.
  • Added DPI support for the GeoCanvas.
  • Improved the TIFF quality for GeoTiffRasterLayer.
  • Changed the logic of GetZoomLevelForDrawing by considering the IsActive.
  • Changed the proj4.GetEpsgParameters(srid) method from instant to static.
  • Changed the Layer.IsVisible to virtual.
  • Checked the IdFieldColumn for all spatial databases like Postgre, Sql2008 and Oracle.
  • Fixed issue when modifying the inner logical of DbfColumn constructor.
  • Fixed issue where GeoTiff was not supported.
  • Fixed issue where the parameter name is wrong for the postgreFeatureLayer's constructor.
  • Fixed issue where TextStyle.Format did not work.
  • Fixed issue involving uppercase conversion when executing SQL in shape file feature source.
  • Fixed issue with GetFeaturesForDrawing logic.
  • Fixed issue with TextStyle.DrawCore DPI.
  • Fixed issue where RasterLayer does not work when the DPI is not 96.
  • Fixed issue where a Postgre Layer will throw “Object reference not set to an instance of an object” exception.
  • Fixed issue involving the first Rotation when setting Rotation projection.
  • Fixed issue where PointStyle.DrawSample() did not work.
  • Fixed issue where the drawing order is not correct when adding multiple types of features to one feature layer.
  • Fixed issue in GetFeaturesByColumnValue.
  • Fixed issue where custom column did not work for the spatial query methods.
  • Fixed issue where the gdiPlusGeoCanvas.DrawCircle() result is not correct.
  • Fixed issue where ExecuteQuery did not work properly.
  • Improved some exception descriptions.
  • Fixed issue where featureLayer.Columns exists, but the featureSource.Columns property does not.
  • Fixed issue with GroupLayer display order.
  • Fixed issue where GetRandomGeoColor was missing.
  • Fixed issue involving sorting classBreaks internally.
  • Fixed issue involving support for all other types like (PolyM) for ShapeFile Layer.
  • Fixed issue involving exposure of static API from ShapeFileFeatureSource to ShapeFileFeatureLayer.
  • Fixed issue where the Transparency property does not work in RasterLayer.
  • Fixed issue where DotDensityStyle was not drawing after CloneDeep.
  • Fixed issue in Map Suite Explorer.
  • Fixed issue where creating a shapeFileLayer by streamloading event would throw an exception in layer.close().
  • Fixed issue involving consideration of the DoNotDraw property or FeaturesToExclude.
  • Fixed issue where TestLayerStyle.DrawSample did not work properly with the haloPen.
  • Fixed issue where GetBoundingBoxOfItems did not work properly.
  • Fixed issue involving label drawing even if the line was visible on the screen.
  • Fixed issue where the CustomFieldFetch event did not work in a ShapeFileFeatureLayer.
  • Fixed issue where GeoPen does not act on symbol Diamond, Diamond2, Star or Star1.
  • Fixed issue where some shape files cannot build an index.
  • Fixed issue where GeoPen and GeoBrush constructors did not work.
Version 3.1.16
Release date: 2/6/2009
  • Added an API(ZoomToOffsetPoint) in ExtentHelper.
  • Added Overloads GetFeaturesInsideBoundingBoxCore and GetFeaturesOutsideBoundingBoxCore.
  • Added a more descriptive message for a ShapeFile validation.
  • Added SaveToProjection in ShapeFileFeatureSource and ShapeFileFeatureLayer.
  • Added a protected virtual property for the cached featureSourceColumns.
  • Added an API in the FeatureSource to refresh the cached columns.
  • Added the API CheckForUnSupportedShapeTypes(string shapeFilePath).
  • Changed the logic to use the InMemoryFeatureSource and InMemoryFeatureLayer.
  • Resolved an issue with style.DrawSample.
  • Resolved System.AccessViolationException when the map is redrawn.
  • A number of API additions. See the API change log for complete details.
Version 3.1.0
Release date: 1/22/2009
  • Added a parameter check to the Projection class.
  • Added a CustomZoomLevels collection to the ZoomLevelSet to allow for custom zoom levels.
  • Added a more descriptive exception message if a PolygonShape or MultiPolygonShape does not pass the validation test.
  • Added HasProjectionText and ProjectionText properties to RasterSource and RasterLayer.
  • Added validation checks on each member of the QueryTools to ensure that the Layer has been opened.
  • Added a new API for getting features based on the value in a column.
  • Added another parameter to BeginDrawing in GeoCanvas.
  • Added ExecuteSqlQuery and CanExecuteSqlQuery methods to QueryTools and FeatureSource.
  • Added two overloads for the method LineShape.GetLineOnLine.
  • Added encoding tests.
  • Added MrSid support in 64-bit environments.
  • Created JPEG2000RasterLayer/JPEG2000RasterSource to make it easier to load JPEG2000 images.
  • Provided an API in ShapeFileFeatureSource and ShapeFileLayer.
  • Updated the documentation for class name changes and for classes that did not previously have documentation.
  • Changed PathFileName to PathFilename.
  • Changed the ReadMe to Readme.
  • Changed the MapSuiteCore class to take advantage of re-projecting an array of points.
  • Changed the internalFeatures from a Dictionary to a GeoCollection.
  • Modified ShapeFileFeatureSource.ExecuteSqlQuery() to throw exception if filename is longer than 8 characters.
  • Enhanced the Projection classes and members.
  • Improved performance in GdiPlusRasterLayer.
  • Improved the Union Sample logic.
  • Improved the exception description for Layer.QueryTools/Layer.EditTools.
  • Improved the documentation for EditTools.Union.
  • Improved speed of spatial queries with a polygon-based layer when using a MultiPolygonShape as the target shape.
  • Improved speed of the Proj4Projection class by removing the locking code.
  • When building an index, all features are now loaded into memory.
  • Fixed missing overload for static method CreateSimpleAreaStyle.
  • Fixed ZoomIn bug.
  • Fixed the PointStyle, AreaStyle and LineStyle DrawSample methods so that they return the sample in the middle of the image.
  • Fixed an outstanding issue with style.DrawSample.
  • Reviewed all of the the Try…Catch code.
  • Resolved issue where the static function BuildRecordIdColumn required a spatial index on the Layer first.
  • Resolved issue where a System.AccessViolationException would be thrown when redrawing the map.
  • Resolved issue with WMS when using a Web Proxy.
  • Resolved issue where dragging two raster layers to Explorer throws an exception.
  • Resolved issue when a Layer's zoom level did not work under a projection other than WGS 84.
  • Resolved issue with ScalebarAdornmentLayer.
  • Resolved issue with RectangleShape.ExpandToInclude.
  • Resolved issue where WmsService would not work with HTTPS/SSL.
  • Resolved issue where mapEngine.OpenAllLayers() would not open an AdornmentLayer.
  • Resolved issue where the Geographic.Unit and DistanceUnit in BaseShape.Buffer() were reversed.
  • Resolved issue with BuildIndex where getting all features would not work.
  • Resolved issue where QueryTools.GetFeaturesContaining would not work when features are in the transaction buffer.
  • Reintroduced the AreaShape.GetCrossings method (which was previously present in Map Suite 2.0).
  • Reintroduced support for raster files (ECW, MrSid, BMP, etc.) in Map Suite Explorer.
  • Removed the obsolete target framework for .NET 2.0.
  • A number of API additions and changes. See the API change log for complete details.
[Category:Map Suite Services Edition] [Category:Web GIS] [Category:Desktop GIS] [Category:GIS] [Category:.NET]
map_suite_services_edition_features_bug_fixes_change_log.1442385001.txt.gz · Last modified: 2015/09/16 06:30 by admin
