map_suite_services_edition_features_bug_fixes_change_log
Map_Suite_Services_Edition_Features_&_Bug_Fixes_Change_Log
Version 9.0.0.0
Release date: 06/24/2015
  • Fixed a bug that the deployed version of WebEddition, MvcEdition, SilverlightEdition and WmsEdition runs into “Unlicensed for runtime”.
  • Fixed a bug where the MagneticDeclinationAdornmentLayer runs into memory issue.
  • Added the new API SetWellKnownBinary(bytemap_suite_services_edition_features_bug_fixes_change_log wkb) to Feature class to allow changing the WKB of the feature.
  • Improved the performance of method bytemap_suite_services_edition_features_bug_fixes_change_log ShapeFile.ReadPolygon(bytemap_suite_services_edition_features_bug_fixes_change_log dataBytes, int startIndex).
  • Added Leader Lines.
Version 8.0.0.160
Release date: 11/17/2014
  • Fixed a bug where it runs into exception if the readed KML file includes the bool value.
Version 8.0.0.0
Release date: 06/06/2014
Version 7.0.0.0
Release date: 06/03/2013
  • Added the ClearCache method to MapPrinterLayer to delete the cache image
  • Added the spatial index status cache for MsSql2008FeatureSource
  • Added support of the FileGeoDatabase
  • Added support off write white paper on Printing
  • Added support of the GRD/GRI grid format
Version 6.0.0.0
Release date: 05/14/2012
Version 5.5.0.49
Release date: 12/31/2011
Version 5.5.0.0
Release date: 11/14/2011
  • Added the IsoLine Support.
Version 5.0.0.55
Release date: 7/7/2011
Version 5.0.0.0
Release date: 5/16/2011
  • Removed the Obsolete APIs.
Version 4.5.0.0
Release date: 11/01/2010
  • Added ClusterPointStyle
Version 4.0.40.0
Release date: 6/15/2010
  • Updated assembly version to 4.0.0.0; included strong-named and weak-named assemblies. Please see the latest post in the Developer Blog for full details.
  • Fixed issue with the ScaleTo API in BaseShape when called by a Rectangle Shape.
  • Fixed issue where an exception would be thrown when calling BuildIndex in a Turkish enviroment.
  • Fixed issue when using the UpdateColumnName API in DBF module.
  • Fixed issue involving use of Chinese fonts
  • Fixed a rounding bug in the GetPointOnALine API of LineShape.
  • Some minor API changes. See the API change log for complete details.
Version 4.0.0
Release date: 5/1/2010
  • Added additional helper methods to the GeoCollection class.
  • Added better support for labeling with Asian characters.
  • Added support for Google Static Maps API v2.
  • Added simple support for Yahoo Maps.
  • Added support for heat map layers.
  • Added support for 100% managed proj Projection Library.
  • Added direct support for Map Shapes.
  • Added API to modify the column name in ShapeFileFeatureSource and ShapeFileFeatureLayer.
  • Added new API BuildIndex for MultipleShapeFileFeatureLayer
  • Included GraticuleLineLayer support and a sample application for it.
  • Enhanced the MultiShapeFileFeaturesLayer class to allow you to use files in multiple folders.
  • Enhanced the distance measuring method to use the Haversine formula.
  • Improved GeoCache performance.
  • Updated the PostgreSQL Assembly versions.
  • Exposed the DBaseFile class library.
  • Exposed the disk-based RTree Spatial Index.
  • Split up the Map Suite MergeModule into smaller and more manageable pieces.
  • Fixed issue where GetCenterPoint using NTS would return an invalid value when the polygon's width and height is 0.
  • Fixed issue regarding GetBoundingBox of GroupLayer.
  • Fixed issue where GetAllColumns also returns the Geometries column.
  • Many API additions. See the API change log for complete details.
  • Updated the API documentation.
Version 3.1.299
Release date: 11/16/2009
  • Fixed issue where SaveToProjection is incorrect for some data.
  • Fixed issue with the DecimalDegreesHelper API GetDecimalDegreeFromDegreesMinutesSeconds.
  • Fixed caculation issue in DecimalDegreeHelper.GetDistanceFromDecimalDegrees when passing particular data.
  • Fixed issue where an exception is thrown for TAB files when the column name starts with an underscore(_).
Version 3.1.273
Release date: 10/22/2009
ThinkGeo.MapSuite.Core Namespace: *Added Haversine formula to calculate distance. *Added DrawException method to draw exceptions rather than throwing them in the Overlay and Layer. *Added IndexedInMemoryFeatureLayer Class. *Added ReadOnly logic to ClearCache and DeleteTile methods. *Added the schema supported in PostgreFeatureSource. *Added API overloads for GetFeaturesByColumnValue method. *Added API to detect the feature type in FeatureSource. *Added API BuildIndex in InMemoryFeatureLayer. *Enhanced the Sql2008FeatureSource, PostgreFeatureSource and OracleFeatureSource by adding one event ExecutingSqlStatement. *Extended the KeyColor from one color to an array of colors or a range of colors. *Fixed a memory leak when calling OpenAllLayers multiple times. *Fixed issue where ApplyUntilZoomLevel doesn't work right when using CustomZoomLevel. *Fixed OutofMemory exception issue in WFSFeatureSource. *Fixed issue where SaveToProjection in ShapeFileFeatureSource would throw an out of memory exception. *Fixed issue with the Stream_Loading event in ShapeFileFeatureSource. *Fixed issue with obfuscation in autobuild. *Fixed issue where the WMS cannot work properly when the network is unavailable. *Fixed issue where GetRandomColor always get the same color. *Fixed issue where CloneDeep of InMemoryFeatureSource does not work. *Fixed issue where InmemoryFeatureSource cannot be serialized correctly. *Fixed issue where you could not parse the parent layer in a WMS server. *Fixed issue where an OutOfMemory error occurs while drawing. *Fixed issue with support for Geography type data in MsSqlFeatureSource. *Fixed issue with the GetFeaturesInsideBoundingBox method of MultipleShapeFileFeatureSource. *Fixed issue where GetCenterPoint using NTS will return an invalid value when the polygon's width and height is 0. *Fixed issue regarding thrown exception ORA-00936: Missing Expression. *Fixed issue where GetPointOnALine returns the wrong value. *Fixed issue where GdiPlusRasterLayer has a black line in tile mode. *Fixed issue with the GetFeatureById API in WfsFeatureLayer. *Fixed very low performance issue with GetColumnsCore. *Fixed issue with missing tag information in InMemoryFeatureLayer. *Fixed non-serializable issue for WFSFeatureLayer. *Fixed issue where an exception was thrown when building an index for an empty shape file. *A number of API changes. See the API change log for complete details.
Version 3.1.182
Release date: 7/23/2009
ThinkGeo.MapSuite.Core Namespace: *Added some APIs for ScaleBar in order to implement the same functionality as in ScaleLine. *Fixed issue with setting a different DPI for canvas. *Fixed issue where the Matrix system did not consider the MapUnit. *Fixed issue where the OverrideMode did not work correctly for the ShapeFileFeatureLayer.SaveToProjection API. *Fixed issue where an exception would be thrown when using a MaskBrush for the ScaleBar. *Fixed issue where bool field cannot be updated in the DBF. *Fixed the Out of Memory Exception thrown when calling the ShapeFileFeatureLayer.SaveToProjection API on very large shape file data. *A number of API changes. See the API change log for complete details.
Version 3.1.124
Release date: 5/26/2009
ThinkGeo.MapSuite.Core Namespace: *Added an API to CheckForUnSupportedShapeTypes(string shapeFilePath). *Added support for a Polygon record that contains 0 parts. *Added an overload for BuildIndexFile. *Added ExecuteQuery support for Postgre. *Added property to show whether the assembly is the Full Version or Evaluation Version. *Added an overload to CreateShapeFile so that user can choose whether they want to override. *Added polygon simplification to AreaShapes. *Added line simplification to LineShapes. *Added obsolete to the AllowSpline property in text style. *Added GetFirstGeometryType in Postgre, Oracle and SQL layers. *Added “Simplify” sample application. *Added an overload to GetFeaturesNeareastTo with a distance limitation. *Added documentation for DashPattern. *Added ToGdiPlusColor method in GeoColor. *Added a way to build a spatial index based on another projection, not using a feature list. *Added DPI support for the GeoCanvas. *Improved the TIFF quality for GeoTiffRasterLayer. *Changed the logic of GetZoomLevelForDrawing by considering the IsActive. *Changed the proj4.GetEpsgParameters(srid) method from instant to static. *Changed the Layer.IsVisible to virtual. *Checked the IdFieldColumn for all spatial databases like Postgre, Sql2008 and Oracle. *Fixed issue when modifying the inner logical of DbfColumn constructor. *Fixed issue where GeoTiff was not supported. *Fixed issue where the parameter name is wrong for the postgreFeatureLayer's constructor. *Fixed issue where TextStyle.Format did not work. *Fixed issue involving uppercase conversion when executing SQL in shape file feature source. *Fixed issue where GetAllColumns also returns the Geometries column. *Fixed issue with GetFeaturesForDrawing logic. *Fixed issue with TextStyle.DrawCore DPI. *Fixed issue where RasterLayer does not work when the DPI is not 96. *Fixed issue where a Postgre Layer will throw “Object reference not set to an instance of an object” exception. *Fixed issue involving the first Rotation when setting Rotation projection. *Fixed issue where PointStyle.DrawSample() did not work. *Fixed issue where the drawing order is not correct when adding multiple types of features to one feature layer. *Fixed issue in GetFeaturesByColumnValue. *Fixed issue where custom column did not work for the spatial query methods. *Fixed issue where the gdiPlusGeoCanvas.DrawCircle() result is not correct. *Fixed issue where ExecuteQuery did not work properly. *Improved some exception descriptions. *Fixed issue where featureLayer.Columns exists, but the featureSource.Columns property does not. *Fixed issue with GroupLayer display order. *Fixed issue where GetRandomGeoColor was missing. *Fixed issue involving sorting classBreaks internally. *Fixed issue involving support for all other types like (PolyM) for ShapeFile Layer. *Fixed issue involving exposure of static API from ShapeFileFeatureSource to ShapeFileFeatureLayer. *Fixed issue where the Transparency property does not work in RasterLayer. *Fixed issue where DotDensityStyle was not drawing after CloneDeep. *Fixed issue in Map Suite Explorer. *Fixed issue where creating a shapeFileLayer by streamloading event would throw an exception in layer.close(). *Fixed issue involving consideration of the DoNotDraw property or FeaturesToExclude. *Fixed issue where TestLayerStyle.DrawSample did not work properly with the haloPen. *Fixed issue where GetBoundingBoxOfItems did not work properly. *Fixed issue involving label drawing even if the line was visible on the screen. *Fixed issue where the CustomFieldFetch event did not work in a ShapeFileFeatureLayer. *Fixed issue where GeoPen does not act on symbol Diamond, Diamond2, Star or Star1. *Fixed issue where some shape files cannot build an index. *Fixed issue where GeoPen and GeoBrush constructors did not work. *A number of API changes. See the API change log for complete details.
Version 3.1.16
Release date: 2/6/2009
ThinkGeo.MapSuite.Core Namespace: *Added an API(ZoomToOffsetPoint) in ExtentHelper. *Added Overloads GetFeaturesInsideBoundingBoxCore and GetFeaturesOutsideBoundingBoxCore. *Added a more descriptive message for a ShapeFile validation. *Added SaveToProjection in ShapeFileFeatureSource and ShapeFileFeatureLayer. *Added a protected virtual property for the cached featureSourceColumns. *Added an API in the FeatureSource to refresh the cached columns. *Added the API CheckForUnSupportedShapeTypes(string shapeFilePath). *Changed the logic to use the InMemoryFeatureSource and InMemoryFeatureLayer. *Resolved an issue with style.DrawSample. *Resolved System.AccessViolationException when the map is redrawn. *A number of API additions. See the API change log for complete details.
Version 3.1.0
Release date: 1/22/2009
ThinkGeo.MapSuite.Core Namespace: *Added a parameter check to the Projection class. *Added a CustomZoomLevels collection to the ZoomLevelSet to allow for custom zoom levels. *Added a more descriptive exception message if a PolygonShape or MultiPolygonShape does not pass the validation test. *Added HasProjectionText and ProjectionText properties to RasterSource and RasterLayer. *Added validation checks on each member of the QueryTools to ensure that the Layer has been opened. *Added a new API for getting features based on the value in a column. *Added another parameter to BeginDrawing in GeoCanvas. *Added ExecuteSqlQuery and CanExecuteSqlQuery methods to QueryTools and FeatureSource. *Added two overloads for the method LineShape.GetLineOnLine. *Added encoding tests. *Added MrSid support in 64-bit environments. *Created JPEG2000RasterLayer/JPEG2000RasterSource to make it easier to load JPEG2000 images. *Provided an API in ShapeFileFeatureSource and ShapeFileLayer. *Updated the documentation for class name changes and for classes that did not previously have documentation. *Changed PathFileName to PathFilename. *Changed the ReadMe to Readme. *Changed the MapSuiteCore class to take advantage of re-projecting an array of points. *Changed the internalFeatures from a Dictionary to a GeoCollection. *Modified ShapeFileFeatureSource.ExecuteSqlQuery() to throw exception if filename is longer than 8 characters. *Enhanced the Projection classes and members. *Improved performance in GdiPlusRasterLayer. *Improved the Union Sample logic. *Improved the exception description for Layer.QueryTools/Layer.EditTools. *Improved the documentation for EditTools.Union. *Improved speed of spatial queries with a polygon-based layer when using a MultiPolygonShape as the target shape. *Improved speed of the Proj4Projection class by removing the locking code. *When building an index, all features are now loaded into memory. *Fixed missing overload for static method CreateSimpleAreaStyle. *Fixed ZoomIn bug. *Fixed the PointStyle, AreaStyle and LineStyle DrawSample methods so that they return the sample in the middle of the image. *Fixed an outstanding issue with style.DrawSample. *Reviewed all of the the Try…Catch code. *Resolved issue where the static function BuildRecordIdColumn required a spatial index on the Layer first. *Resolved issue where a System.AccessViolationException would be thrown when redrawing the map. *Resolved issue with WMS when using a Web Proxy. *Resolved issue where dragging two raster layers to Explorer throws an exception. *Resolved issue when a Layer's zoom level did not work under a projection other than WGS 84. *Resolved issue with ScalebarAdornmentLayer. *Resolved issue with RectangleShape.ExpandToInclude. *Resolved issue where WmsService would not work with HTTPS/SSL. *Resolved issue where mapEngine.OpenAllLayers() would not open an AdornmentLayer. *Resolved issue where the Geographic.Unit and DistanceUnit in BaseShape.Buffer() were reversed. *Resolved issue with BuildIndex where getting all features would not work. *Resolved issue where QueryTools.GetFeaturesContaining would not work when features are in the transaction buffer. *Reintroduced the AreaShape.GetCrossings method (which was previously present in Map Suite 2.0). *Reintroduced support for raster files (ECW, MrSid, BMP, etc.) in Map Suite Explorer. *Removed the obsolete target framework for .NET 2.0. *A number of API additions and changes. See the API change log for complete details.
Map Suite Services Edition Web GIS Desktop GIS GIS .NET
map_suite_services_edition_features_bug_fixes_change_log.1441787906.txt.gz · Last modified: 2015/09/09 08:38 by admin
