map_suite_server_world_streets
Map Suite Server World Streets
The Map Suite Server World Streets is an extension for our Map Suite line of GIS developer controls that includes everything you need to display professional-looking maps of any location on Earth. The kit comes with detailed map data covering the entire world. The included source code allows you to redesign the maps or add your own data easily.
Product Guides
This guide walks you through installing the Map Suite Server World Street on your system and creating a simple GIS application.
This guide walks you through using SQLite as a storage format.
This guide walks you through using restoring your PostgreSQL backup file.
Code Samples
All Samples
All samples about Map Suite Server World Street.
Project Templates
These projects show various study cases based on Map Suite Server World Street.
NOTE: We have provided several sample applications with source code to help you learn the different capabilities of Map Suite. Each code sample includes an overview, complete source code online to review and the ability to download the sample and run it yourself.
Demo & Screenshots
To see what the maps look like, check out the online demo at maps.thinkgeo.com.
Frequently Asked Questions
  • General Questions
    These FAQ's cover general questions about the Map Suite Server World Streets product.
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
Screenshots
The Map Suite Desktop for Wpf screenshots gallery section displays a wide range of screenshots covering various GIS features of the Map Suite Desktop for Wpf map control.
Add rich aerial imagery
Supports JPEG2000, TIFF, MrSid, ECW and more
Add rich aerial imagery Supports JPEG2000, TIFF, MrSid, ECW and more
SQL query feature layers
Get column data
Visually render SQL data
SQL query feature layers Get column data Visually render SQL data
Uses ZedGraph classes
Automatic color family generation
Group colors by hue or quality
Automatic color family generation Group colors by hue or quality
Draw or exclude features based on conditions
Render based on data points
Draw or exclude features based on conditions Render based on data points
Restrict drawing of features
Fill restricted areas with patterns or bitmaps
Restrict drawing of features Fill restricted areas with patterns or bitmaps
Plots points on your map
Point density represents numeric data
Puts you in control
Useful for points & labels
Render features specifically based on a theme
Colorize map features
Project your spatial data
Real-time rotation
Draw an image at a point
Dozens of interactive sample applications
Source code in C#
Dozens of interactive sample applications Source code in C#
map_suite_server_world_streets.1495791546.txt.gz · Last modified: 2017/05/26 09:39 by tgwikiupdate
