map_suite_runtime_license_guide_for_desktop
MapSuite Runtime License Guide For Desktop
What is Runtime License
If you need to publish the desktop application that developed with Map Suite desktop components, it's required to publish your application along with the Runtime License, otherwise, map will rendered with “Not Licensed for Run Time”. This guide will show you how to setup the runtime license.
Get Runtime License From Map Suite Product Center
Runtime License can be generated by “Map Suite Product Center” where you can find from package installation folder (…packages\ThinkGeo.MapSuite.ProductCenter.10.0.0\lib\net45). Please double click the ThinkGeo.MapSuite.ProductCenter.exe. Then let’s switch to the WinForms tab as Figure 1 indicates.
Generate Runtime License File
Select the application that you want to publish. If you've activated or started trail for desktop. “Runtime License” section can be found at right side of Product Center. (See figure 2.)
Figure 2. Generate Runtime License Item.
Click on the Browse button and select your application which you want to publish.
“Save As” dialog will pop up after application selected. Click “Save” button to generate runtime license file(*.mapsuitelicense) on your disk.
Now the runtime license is ready for this application.
map_suite_runtime_license_guide_for_desktop.1487561256.txt.gz · Last modified: 2017/02/20 03:27 by marklee
