If you need to publish the desktop application that developed with Map Suite desktop components, it's required to publish your application along with the Runtime License, otherwise, map will rendered with “Not Licensed for Run Time”. This guide will shows you how to setup setup the runtime license.
Runtime License can be generated by “Map Suite Product Center” that you can find the “Map Suite Product Center” from package installation folder (…packages\ThinkGeo.MapSuite.ProductCenter.10.0.0\lib\net45). Please double click the ThinkGeo.MapSuite.ProductCenter.exe. Then let’s switch to the WinForms tab as Figure 1 indicates.
Select your product click “Runtime License Browse” button (See figure 2.) after active your product.
Figure 2. Generate Runtime License Item.
Select your application which you want to release.
“Save As” dialog will be pop up after select your application. Generate a runtime license file in your application folder (*.mapsuitelicense).
You can double click and run your application after the runtime license saved to your application folder.
