Applies To:
Map Suite Routing Silverlight Edition How Do I Samples====^ Screenshot ^ width=78|Sample ^ width=66|Products ^ Description ^|
| C# Download
VB Download | Routing,
Silverlight | The Map Suite Routing “How Do I?” solution offers a series of useful how-to examples for using the Map Suite Routing extension. The bundled solution comes with a small set of routable street data from Austin, TX and demonstrates simple routing, avoiding specific areas, getting turn-by-turn directions, optimizing for the Traveling Salesman Problem, and much more. Full source code is included in both C# and VB.NET languages; simply select your preferred language to download the associated solution.
Please note that you will need an evaluation (or full version) of both Map Suite Routing and Map Suite Silverlight Edition to build and run these samples.
