map_suite_routing_features_bug_fixes_change_log
Map Suite Routing Features & Bug Fixes Change Log
Version 9.0.0.0
Release date: 06/24/2015
Release - No Changes
Version 8.0.0.0
Release date: 06/06/2014
ThinkGeo.MapSuite.Routing Namespace:
  • Fixed a bug where routing within one road segment which is one-way type doesn't work.
  • Fixed a bug where the Route property of RoutingResult always returns a new created instance.
  • Fixed a bug where GenerateServiceArea runs into “Input string not in a correct format” exception when using X,Y overload.
  • Fixed a bug that BuildRoutingData method with routableShapeFile parameter creates another new shapefile.
Version 7.0.0.0
Release date: 06/03/2013
  • Added method to allow for a route to be returned as a single LineShape
  • Fixed a bug that SingleLineShape Route is not clipping correctly
  • Fixed a bug that SingleLineShape Route is not snapping to features correctly
  • Fixed a bug that Service Area Definition does not work if the start feature is near the border of the routing shape file
  • Fixed a bug that RoutingResult can't get closest point result
  • Fixed a bug that the Route returned is much longer than expected
  • Fixed a bug that a clicked point does not snap to the nearest road and sometimes returns a random road segment
  • Fixed a bug that where the route result is incorrect if the stop points are on a same road
  • Fixed some spelling issues in Routing “How Do I” samples
  • Fixed lots of bugs for Map Suite Routing Explorer
  • Improved the performance greatly when routing with several stops
  • Improved the performance of getRoute based on several stop points a lot
  • Improved the route result to make sure it return an ordered LineShape
Version 6.0.0.0
Release date: 05/14/2012
  • Fixed an issue where the process is hang up when routing with only one stopping point.
Version 5.5.0.49
Release date: 12/31/2011
ThinkGeo.MapSuite.Routing Namespace: *Fixed an issue where it returns wrong route for some scenarios.
Version 5.5.0.0
Release date: 11/14/2011
ThinkGeo.MapSuite.Routing Namespace: *Fixed an issue where the Features doesn't match RoadSegments in RoutingResult. *Added GetRoute overload methods and obsoleted some old APIs.
Version 5.0.0.0
Release date: 5/16/2011
ThinkGeo.MapSuite.Routing Namespace: *Fixed a bug in RoutingEngine.GetRouteViaVisitStops method which would throws exceptions for some cases due to not passing simple shape validations. *Added validations to check if the file extension is allowed. *Added support for routing results as a single lineshape or as multiple lineshapes. *Added GenerateRoutableShapeFile method to create routable shapefiles.
Version 4.5.43.0
Release date: 12/14/2010
ThinkGeo.MapSuite.Routing Namespace: *Upgraded the Routing Index Format to speed up performance. *Added override method GetRouteViaStops, which allows you to get the route using feature IDs. *Added many validations for the public API, such as checking file extension, etc. *Fixed an issue with TSP initial route distance. *Fixed an issue with the GetRouteDirections sample.
Version 4.0.40.0
Release date: 6/15/2010
ThinkGeo.MapSuite.Routing Namespace: *Updated assembly version to 4.0.0.0; included strong-named and weak-named assemblies. Please see the latest post in the Developer Blog for full details.
Version 4.0.0
Release date: 5/1/2010
ThinkGeo.MapSuite.Routing Namespace: *Added Visual Studio 2010 support. *Added routing support for the Travelling Salesman Problem with fixed start and end points. *Added more sample applications for new scenarios. *Fixed issue where an unexpected error would occur when routing on complex road networks. *Fixed issue that optimizes the route on the last point for Travelling Salesman. *Fixed issue with TSP initial route distance. *Several API additions. See the API change log for complete details. *Updated the API documentation.
Version 3.1.299
Release date: 11/16/2009
ThinkGeo.MapSuite.Routing Namespace: *Concluded public beta and moved to final release. *Added support for the Traveling Salesman Problem. *Added a set of Silverlight-based “How Do I?” sample apps. *Added a set of Web-based “How Do I?” sample apps including VB.NET and C# source code. *Some API revisions, including one breaking change. See the API change log for complete details.
Map Suite Routing Web GIS Desktop GIS GIS .NET
map_suite_routing_features_bug_fixes_change_log.1441789015.txt.gz · Last modified: 2015/09/09 08:56 by admin
