map_suite_routing_faq_layers_featuresources
Map_Suite_Routing_FAQ_Layers_&_FeatureSources
How do I find the points of interests within certain distance of a route?
Sample:POI on Route
In today’s project, we are looking at the Routing extension of Map Suite. As a reinforcement of what we learned in the samples of “How Do I”, we show how to find the shortest route between the start and the end point. In addition to that, we show how to use the MultiLineShape from the result of the GetRoute function to do a spatial query to get the points of interests (POI) on the route. For this sample, you would need a reference of either the full or evaluation of MapSuiteCore.dll and MapSuiteRouting.dll.
Sample:POI on route(Advanced)
In the project “POI on route”, we learned how to get the points of interests (POI) on the route within a certain buffer distance. In today’s project, we are going to go a step further and we show the technique for finding the POIs according to what side of the route they are located. For example, in the delivery industry, it is far more efficient to deliver to stops on the right side of the road when driving on the right side of the road.
How do I route in one projection and display the route information in another projection?
Sample:Routing with Projections
How do I modify data to make them one-way streets?
Sample:One Way Street Builder
In the sample apps “How Do I” of the Routing product, we have a sample that shows how the route is constructed on a one way street. Today’s project is meant to complement by showing how to set selected streets to be one way and in the desired direction. From this sample, you can create your own utility to handle your data for routing purposes.
Map Suite Routing Web GIS Desktop GIS GIS .NET
map_suite_routing_faq_layers_featuresources.1440040123.txt.gz · Last modified: 2015/09/11 03:59 (external edit)
