This class represents a routing algorithm that is based on the Bidirectional algorithm.
This class represents the parameters passed out through the FindingServiceArea event.
This class represents the parameters passed out through the GettingTspVisitRoute event.
This layer can show start coordinates, end coordinates, a collection of in-between stops and the resulting paths with specified styles.
This class represents the result of routing. RoutingResult is the roads collection consisting of the route, turn-by-turn directions and other information like total distance and route path.
This class represents the parameters passed out through the FindingRoute event.
This class represents the parameters passed out through the BuildingRoutingData event.
This class represents a routing algorithm that is based on the Dijkstra algorithm.
This is the event arguments class for the AdornmentLayersDrawn event. It is raised after all of the AdornmentLayers have been drawn.
This class represents a NativeImageTile, which is defined as scale, RectangleBox and a byte array for its tile bitmap.
This class is a concrete class inherits from BitmapTileCache. In this class, the tiles will be saved in memory and it provides some properties to control it very easily.
This is the base class for NativeTileCache system which inherits from TileCache class.
This class represents the parameters passed in through the CreatedMemberNode event.
This class represents the parameters passed in through the CreatingMemberObject event.
Indicates how the default value of a member will be dealt with by the modeler.
When applied to a method, specifies that the method is called after serialization of an object graph.
When applied to a method, specifies that the method is called before serialization of an object.
