Please note that you will need an evaluation (or full version) of both Map Suite Routing and Map Suite Desktop Edition to build and run these samples.
Please note that you will need an evaluation (or full version) of both Map Suite Routing and Map Suite Silverlight Edition to build and run these samples.
Please note that you will need an evaluation (or full version) of both Map Suite Routing and Map Suite Web Edition to build and run these samples.
The Map Suite Routing Index Generator is a utility that will allow you to generate routing index files (“.rtg” and “.rtx”) from ESRI shapefiles and .sqlite databases. These routing index files will be used by the Map Suite Routing Extension in order to calculate routes and driving directions. This utility allows you to specify things that one-way road information, as well as configuring the road speed and type of routes you would like to calculate. It is easily extendable to allow you to add code to deal with other routing situations. This version of the RoutingIndexGenerator requires v9.0.515.0 or higher of both MapSuiteCore.dll and SQLiteExtension.dll.
