map_suite_routing_all_samples
Map Suite Routing All Samples
Map Suite Routing Desktop Edition How Do I Samples
Please note that you will need an evaluation (or full version) of both Map Suite Routing and Map Suite Desktop Edition to build and run these samples.
Map Suite Routing Silverlight Edition How Do I Samples
Please note that you will need an evaluation (or full version) of both Map Suite Routing and Map Suite Silverlight Edition to build and run these samples.
Map Suite Routing Web Edition How Do I Samples
Please note that you will need an evaluation (or full version) of both Map Suite Routing and Map Suite Web Edition to build and run these samples.
POI on Route
In today’s project, we are looking at the Routing extension of Map Suite. As a reinforcement of what we learned in the samples of “How Do I”, we show how to find the shortest route between the start and the end point. In addition to that, we show how to use the MultiLineShape from the result of the GetRoute function to do a spatial query to get the points of interests (POI) on the route.
For this sample, you would need a reference of either the full or evaluation of MapSuiteCore.dll and MapSuiteRouting.dll.
POI on route(Advanced)
In the project “POI on route”, we learned how to get the points of interests (POI) on the route within a certain buffer distance. In today’s project, we are going to go a step further and we show the technique for finding the POIs according to what side of the route they are located. For example, in the delivery industry, it is far more efficient to deliver to stops on the right side of the road when driving on the right side of the road.
Routing Tolerance
In today’s project, we will see how to better leverage the GetRoute function of the RoutingEngine by doing some spatial query. The GetRoute function allows you to pass two PointShapes for the start and end points of the route to build. If a PointShape is not on a line segment of the routable street data, the closet point on the closest segment will be used regardless of how far the PointShape is. Using the Spatial Query function, GetFeaturesWithinDistanceOf, we check if the PointShapes passed as start and end points are within some tolerance before proceeding with building the route.
For this project, you will need MapSuiteCore.dll and MapSuiteRouting.dll references.
Routing with Projections
One Way Street Builder
In the sample apps “How Do I” of the Routing product, we have a sample that shows how the route is constructed on a one way street. Today’s project is meant to complement by showing how to set selected streets to be one way and in the desired direction. From this sample, you can create your own utility to handle your data for routing purposes.
map_suite_routing_all_samples.1444281338.txt.gz · Last modified: 2015/10/08 05:15 (external edit)
