map_suite_projection
Map Suite WebAPI Projection
Video Overview
Coming soon
Overview
This sample shows you Map Projection. It uses different projection (Meter, DecimalDegree), rotation projection and custom projection, you can get projection’s information and render your data under these projection. In this sample, we create client-side with the JavaScript mapping library, Leaflet or OpenLayers.
Meter Projection
EPSG3857
In this sample, the map uses EPSG3857. There are two layers, one is ThinkGeo WorldMapKit as basemap created by client-side, the other one is all the countries layer created by the server-side.
DecimalDegree Projection
EPSG4326.
In this sample, the map uses EPSG4326. There are two layers, one is ThinkGeo WorldMapKit as base map created by client-side, the other one is all the countries layer created by the server-side.
Rotation Projection
Rotation Projection.
In this sample, the map uses EPSG3857. We render all the countries, US highway and Major cities with the custom overlay that’s coming from the server-side. On the server-side we use rotation projection with given angle and pivot center. We can change the angle by the button on the upper right corner, and when we move the map, the pivot center will automatically change.
Rotation Projection
Custom Projection: EPSG2163.
In this sample,The map uses EPSG2163, we are overlaying all the countries with the custom overlay that’s coming from the server-side.
map_suite_projection.1448958665.txt.gz · Last modified: 2015/12/01 08:31 by tgwikiupdate
