Coming soon
This sample shows you Map Projection. It is using different projection (Meter, DecimalDegren), rotation projection, and custom projection, you can view projection’s information and render your data under these projection. In this sample we create client-side with Leaflet and Openlayers.
In this sample, the map is using EPSG3857. We are pulling in two layers, one is ThinkGeo WorldMapKit as base map created by client-side, the other one is all the countries layer created by the server-side.
In the sample, map is using EPSG4326. We are pulling in two layers, one is ThinkGeo WorldMapKit as base map created by client-side, the other one is all the countries layer created by the server-side.
In this sample, map is using EPSG3857, we are overlaying all the countries, and US highway and Major cities with the custom overlay that’s coming from the server-side. On the server-side we are using rotation projection with given angle and pivot center. We can change the angle by the button on the upper right corner, and when we move the map, the pivot center will automatically change.
