View Source |
C# Download |
Need it in another language?
View Source |
C# Download |
View Source |
C# Download |
This web-based project demonstrates how to customize the ZoomLevels of your Map Suite Web Edition map. There are 20 default ZoomLevels, but sometimes they don’t fit your requirements. In that case, you can specify your own scale which corresponds to a certain ZoomLevel. It’s easy to do and requires just a few lines of code.
View Source |
C# Download |
View Source |
C# Download |
View Source |
C# Download |
Applies To: MVC \ Web
View Source |
C# Download |
Applies To: MVC \ Desktop \ Web \ Silverlight \ Services \ Wpf
View Source |
C# Download |
View Source |
C# Download |
View Source |
C# Download |
View Source |
C# Download |
View Source |
C# Download |
