map_suite_mvc_edition_zooming_panning_moving_samples
Map Suite MVC Edition Zooming Panning Moving Samples
Center Map Based On Lat/Long
View Source | C# Download | Need it in another language? | Web
Centering Map with Tolerance
View Source | C# Download | Need it in another language? | Desktop
Customize ZoomLevels
This web-based project demonstrates how to customize the ZoomLevels of your Map Suite Web Edition map. There are 20 default ZoomLevels, but sometimes they don’t fit your requirements. In that case, you can specify your own scale which corresponds to a certain ZoomLevel. It’s easy to do and requires just a few lines of code.
GetZoomLevel
Map Scales
Moving Features with Ajax
Applies To: MVC \ Web
Raster Layer with extent
Applies To: MVC \ Desktop \ Web \ Silverlight \ Services \ Wpf
Restricting Extent
Zoom In To Feature
Zoom In To Point
Zoom Levels Partitioning
Zoom to Full extent
View Source | C# Download | Need it in another language? | Wpf
map_suite_mvc_edition_zooming_panning_moving_samples.1441181456.txt.gz · Last modified: 2015/09/02 08:10 by admin
