View Source |
C# Download |
Need it in another language? |
Wpf
View Source |
C# Download |
Desktop
View Source |
C# Download |
Desktop
View Source |
C# Download |
Desktop
View Source |
C# Download |
Web
Applies To: MVC \ Web \ Silverlight
View Source |
C# Download |
Web
View Source |
C# Download |
Desktop
Applies To: MVC \ Desktop \ Web \ Silverlight \ Services \ Wpf
View Source |
C# Download |
Wpf
View Source |
C# Download |
Wpf
This sample will show you how to find the closest line between two features by using the <tt>GetShortestLineTo</tt> API and how to split a line at a given point using the GetLineOnALine API. These APIs can be very useful when doing spatial analysis and editing of features. This sample also allows you to dynamically alter the test features using the EditOverlay so you can try out different scenarios and see the results quickly. A MapShapes layer is used to display and style the individual results.
View Source |
C# Download |
Desktop
