map_suite_mvc_edition_spatial_functions_samples
Map Suite MVC Edition Spatial Functions Samples
Clipping On Line Layer
View Source | C# Download | Need it in another language? | Wpf
Create Inner Ring
View Source | C# Download | Need it in another language? | Desktop
FeatureIdsToExclude
Get Feature Clicked On(Web)
View Source | C# Download | Need it in another language? | Web
Applies To: MVC \ Web \ Silverlight
Get Feature Clicked On(Web)2
Intersect Line
Applies To: MVC \ Desktop \ Web \ Silverlight \ Services \ Wpf
Polygon Shapes To Multipolygon Shapes
Shortest Line Between Two Features with Split
This sample will show you how to find the closest line between two features by using the <tt>GetShortestLineTo</tt> API and how to split a line at a given point using the <tt>GetLineOnALine</tt> API. These APIs can be very useful when doing spatial analysis and editing of features. This sample also allows you to dynamically alter the test features using the <tt>EditOverlay</tt> so you can try out different scenarios and see the results quickly. A MapShapes layer is used to display and style the individual results.
Sweep Angle Desktop
map_suite_mvc_edition_spatial_functions_samples.1441161843.txt.gz · Last modified: 2015/09/02 02:44 by admin
