View Source |
C# Download |
Need it in another language? |
Wpf |
Applies To: MVC \ Web \ Wpf
View Source |C# Download |
Desktop |
Applies To: MVC \ Desktop \ Web \ Silverlight \ Services \ Wpf
View Source |
C# Download |
Desktop |
View Source |
C# Download |
Desktop |
This sample shows how you can display multiple labels for a given point or feature. You can do this by setting a single TextStyle or multiple TextStyles. If you use a single TextStyle, you can simply use a pattern like “ColumnName1[ColumnName2]…” and when Map Suite displays the text it will combine the values of the columns in your pattern. If you use a different styling method, you will need to manually control the offset of each piece of text to avoid overlapping.
