map_suite_mvc_edition_labeling_samples
Map Suite MVC Edition Labeling Samples
Draggable Labels
View Source | C# Download | Need it in another language? | Wpf | Applies To: MVC \ Web \ Wpf
Labeling based on size
View Source |C# Download | Need it in another language? | Desktop | Applies To: MVC \ Desktop \ Web \ Silverlight \ Services \ Wpf
MultiLine Labeling
View Source | C# Download | Need it in another language? | Desktop | Applies To: MVC \ Desktop \ Web \ Silverlight \ Services \ Wpf
Multiple Labels
This sample shows how you can display multiple labels for a given point or feature. You can do this by setting a single TextStyle or multiple TextStyles. If you use a single TextStyle, you can simply use a pattern like “ColumnName1[ColumnName2]…” and when Map Suite displays the text it will combine the values of the columns in your pattern. If you use a different styling method, you will need to manually control the offset of each piece of text to avoid overlapping.
map_suite_mvc_edition_labeling_samples.1440749160.txt.gz · Last modified: 2015/08/28 08:06 by admin
