In the Discussion Forum post “Display word-wrapped text”, there is a discussion on how to implement a TextStyle doing word wrapping. In this project, you will actually find a working implementation. Notice that by using the class WordWrappingTextStyle, word-wrapping is applied according the proportion of the size of the text to the size of the bounding box of the feature to label. This means that the label can be word-wrapped or not depending on the zoom level.<br> You can find the discussion forum post on that topic at:<br> http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6421/afv/topic/Default.aspx
This project is a follow up to the Discussion Forum post http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6652/afv/topic/Default.aspx Rotating the feature text (similar to wordwrap). In this project, we create a new Text Style combining word wrapping that we saw in the project http://code.thinkgeo.com/projects/show/wordwrapped and text rotation. You can see the labels word wrapping and rotating in harmony with the resizing and rotating of the shapes.
