map_suite_mvc_edition_faq_styles
Table of Contents
Map_Suite_MVC_Edition_FAQ_Styles
Sample: Cached Value Style
How do I cluster multiple points into one point for display?
Sample:ClusterPointStyle
In this project, you will see how to use a custom style, ClusterPointStyle for clustering various features into one. Sometimes, the map may have many features stacked on top of each other at high zoom levels making the map too busy and difficult to read. Clustering is a usefull technique in those situation making the map more readable. It groups together various features into one symbol with the count of all the features being labeled.<br> There are many ways for finding the location of the cluster point. One of the simplest is to use the center of gravity of all the clustered features as used in this project.<br> In this project, we are using volcanoes because natural phenomenon are usually good candidates for being clustered.
How do I display a label in real world dimensions?
Sample:World Sized Text Style
How do I display an icon in real world dimensions?
How do I word wrap my labels?
Sample:WordWrapped TextStyle
In the Discussion Forum post “Display word-wrapped text”, there is a discussion on how to implement a TextStyle doing word wrapping. In this project, you will actually find a working implementation. Notice that by using the class WordWrappingTextStyle, word-wrapping is applied according the proportion of the size of the text to the size of the bounding box of the feature to label. This means that the label can be word-wrapped or not depending on the zoom level.<br> You can find the discussion forum post on that topic at:<br> http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6421/afv/topic/Default.aspx
How do I draw features differently based on column values?
How can I display decimal degrees as degrees, minutes and seconds?
How do I display a point based on real time data such as the current time?
Sample:Time Based Point Style
How do I label each line in a MultiLineShape?
How can I show one-way streets arrows on my roads?
How do I draw a line with a different start and end style?
Sample:Start End LineStyle
How do I display the distance of a line as label?
Sample:Distance Line Style
How do I display a point as a doughnut shape?
Sample:Doughnut Point Style
How do I draw points where the size is proportional to a column value?
Sample:Sized Point Style
How do I rotate a side view icon based on its heading?
Sample:Side View Icon
Sample:EditOverlay Styles
How do I draw an icon that flashes?
Sample:Flashing Point Style
How do I make a text larger or smaller based on the current scale?
Sample:Scaling TextStyle
How do I make an icon larger or smaller based on the current scale?
Sample:Scaling Image Style
How do I create a custom style to display routes?
Sample:Routing Styles
Sample:Rotate Icon
Sample:Rotated Image Style
Sample:Vehicle Direction
How do I rotate a feature's text similar to word wrapping?
Sample:Hybrid TextStyle
This project is a follow up to the Discussion Forum post http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6652/afv/topic/Default.aspx Rotating the feature text (similar to wordwrap). In this project, we create a new Text Style combining word wrapping that we saw in the project http://code.thinkgeo.com/projects/show/wordwrapped and text rotation. You can see the labels word wrapping and rotating in harmony with the resizing and rotating of the shapes.
How do I set multiple dot density styles on the map?
How to create a cutomer valuestyle?
Sample:Default ValueStyle
How to create a line style with increment?
How do I display multi line labeling?
Sample:MultiLine Labeling
How to create a weather line style?
Sample:Weather Line Style
Sample:Isolines
Yes. Starting with build 5.0.87.0 of Map Suite, you can add isolines to your applications with Map Suite – please see the code sample linked above. For the uninitiated, isolines are a way to visualize breaks between different groups of data such as elevation levels, soil properties, or just about anything else you can imagine. The above code sample also shows the various steps in creating isolines, including the gathering of point data, creating a grid using interpolation, and finally, picking your isoline break levels. We also quickly dive into some more advanced options such as generating isolines on the fly. To bring this all together, check out our [[Media:ServicesEditionSample_Isolines_110809.wmv|instructional video]] that will walk you through the process of setting up and working with isolines in Map Suite.
Map Suite MVC Edition Web GIS Desktop GIS GIS .NET
map_suite_mvc_edition_faq_styles.1440040123.txt.gz · Last modified: 2015/08/28 06:14 (external edit)
