map_suite_mvc_edition_azure_deployment_guide
Map Suite MVC Edition Azure Deployment Guide
The purpose of this guide is to show you how to upload your MVC Edition Sample to Azure Server, and at the same time install the MVC Server Edition to remove the watermark after deployment. It is using 3 key files( one cmd , one exe and one msi). MVC Server Edition serial number needs to be upgraded in the cmd file to pass the online validation.
This guide works with Map Suite 7.0 MVC Edition. If you are using 7.0.0.0 assemblies you can directly use the attached tools. If you are using a newer version please replace the “Setup Unmanaged Dependencies 7.0.0.0.msi” and update the corresponding script in MapSuiteMVCServerAzureInstaller.cmd.
Download the Sample
Download This Sample ( 24.12 MB)
Setting up the Environment
Run VS as administrator and create Windows Azure Cloud Service
Add a MVC 3 web role
Add a shapefile to the project and write code as following to display it on the map
<source lang=“csharp”> Map map = new Map(“Map1”, new System.Web.UI.WebControls.Unit(99, System.Web.UI.WebControls.UnitType.Percentage), 460);
map.MapBackground.BackgroundBrush = new GeoSolidBrush(GeoColor.FromHtml(“#E5E3DF”)); map.CurrentExtent = new RectangleShape(-131.22, 55.05, -54.03, 16.91); map.MapUnit = GeographyUnit.DecimalDegree; map.MapTools.PanZoomBar.Enabled = true; map.MapTools.MouseCoordinate.Enabled = true;
ShapeFileFeatureLayer layer = new ShapeFileFeatureLayer(Server.MapPath(“SampleData/cities_a.shp”)); layer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.Capital1; layer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
LayerOverlay overlay = new LayerOverlay(); overlay.Layers.Add(layer);
map.CustomOverlays.Add(overlay);
return View(map);
</source>
Copy the 3 files to the project folder and reference them into your project
Set the 3 files’ Build Action to "Content" and Copy to Output Directory to "Copy Always"
Change the MapSuiteMVCServerAzureInstaller.cmd by typing in the license key, then rebuild
Add a new node to the ServiceDefinition.csdef under WebRole node as following
<Startup><Task commandLine="MapSuiteMVCServerAzureInstaller.cmd" executionContext="elevated" taskType="simple"></Task></Startup>
Publish it, the MVC server edition should have been installed and no watermark will be shown on the Map Suite Map.
map_suite_mvc_edition_azure_deployment_guide.1441007334.txt.gz · Last modified: 2015/08/31 07:48 by admin
