map_suite_mobile_for_ios_features_bug_fixes_change_log
Map Suite Mobile For iOS Features & Bug Fixes Change Log
Version 10.4.0
Release date: 12/10/2018
ThinkGeo.MapSuite.iOS Namespace:
ThinkGeo.MapSuite Namespace:
  • Added new overloading method for DrawText in GeoCanvas class
  • Enhanced to get better performance for data drawing when shape file contains many inner rings in polygon
  • Enhanced to support Esri srid input for Proj4Projection
  • Enhanced to support Esri coordinate system when create table for FileGeoDatabase
  • Enhanced to use more accurate exception information and exception type
  • Fixed a bug map throw null reference exception in certain scenario
  • Fixed a bug the Sqlite R Tree calculate different result in Windows and Linux
  • Fixed a bug some special invalid saturation and luminance values for GeoColor can pass our validation
  • Fixed a bug vector data won't render all shapes if the width is too big
  • Fixed a bug XyzFileBitmapTileCache lose cache ID in certain scenario
  • Fixed a bug GettingTileCache event won't be fired in correct step
  • Fixed a bug the overlays don't match when print to PDF
  • Fixed a bug white line shows for WMTSlayer
  • Fixed a bug exception is thrown when met invalid tile in WMTSlayer
  • Fixed a bug failed to load dll in FileGeoDatabase for asp.net scenario
  • Fixed a bug ECW render distorted image in special zoomlevel
  • Fixed a bug GeoTiff image jump in certain scenario
Version 10.3.0
Release date: 7/26/2018
  • Fixed a bug that iOS package calculates incorrect position differently from OSM
  • Fixed a bug that building overlay doesn't work after deploy to physical device
Version 10.2.0
Release date: 10/27/2017
  • Supported for 3D rendering for buildings(Overlay level)
Version 10.1.0
Release date: 06/21/2017
Version 10.0.0
Release date: 02/16/2017
Map Suite 10.0 New Features:
  • Synchronize the Core APIs across all Map Suite product line.
  • Added GeoHatchStyle support.
  • Added more properties on GPSMarker for customization.
  • Added DrawingQuality on Overlay.
  • Refined the code for requesting cancellation.
  • Fixed a NullReferenceException for TileOverlay.
  • Fixed xml namespace bug for TiledWmsRasterSource
  • Fixed tile matrix unit issue for GoogleMap.
  • Fixed a bug that getting stream from uri returns null.
  • Fixed a hard-code setting in WmsOverlay.
  • Fixed a bug that HeatStyle renders incorrectly.
  • Fixed an incorrect “copyright” character for the default attribution.
  • Fixed a bug that adds tiles repeatedly.
  • Added style sheets support.
Version 9.0.0.0
Release date: 06/24/2015
ThinkGeo.MapSuite.iOSEdition Namespace:
  • Fixed a bug where there are something wrong with the map events when it is not full screen.
  • Added RestrictExtent and max/min scales range limits.
  • Added support of requesting tiles image from MapBox services.
  • Fixed a bug where the OperationQueue throws exception after transferring to Unified API.
  • Fixed a bug where the continuously panning doesn't stop the previous panning animation.
  • Fixed a bug where drawing raster files to an unexpected area.
  • Supported Unified API to allow user to build 64bit apps.
  • Added Leader Lines.
map_suite_mobile_for_ios_features_bug_fixes_change_log.1544499386.txt.gz · Last modified: 2018/12/11 03:36 by tgwikiupdate
