map_suite_mobile_for_ios_features_bug_fixes_change_log
Map Suite Mobile For iOS Features & Bug Fixes Change Log
Version 10.1.0.0
Release date: 06/21/2017
ThinkGeo.MapSuite.iOS Namespace:
ThinkGeo.MapSuite Namespace:
Version 10.1.0.0
Version 10.0.0.0
Release date: 02/16/2017
Map Suite 10.0 New Features:
  • Synchronize the Core APIs across all Map Suite product line.
  • Added GeoHatchStyle support.
  • Added more properties on GPSMarker for customization.
  • Added DrawingQuality on Overlay.
  • Refined the code for requesting cancellation.
  • Fixed a NullReferenceException for TileOverlay.
  • Fixed xml namespace bug for TiledWmsRasterSource
  • Fixed tile matrix unit issue for GoogleMap.
  • Fixed a bug that getting stream from uri returns null.
  • Fixed a hard-code setting in WmsOverlay.
  • Fixed a bug that HeatStyle renders incorrectly.
  • Fixed an incorrect “copyright” character for the default attribution.
  • Fixed a bug that adds tiles repeatedly.
  • Added style sheets support.
Version 9.0.0.0
Release date: 06/24/2015
ThinkGeo.MapSuite.iOSEdition Namespace:
  • Fixed a bug where there are something wrong with the map events when it is not full screen.
  • Added RestrictExtent and max/min scales range limits.
  • Added support of requesting tiles image from MapBox services.
  • Fixed a bug where the OperationQueue throws exception after transferring to Unified API.
  • Fixed a bug where the continuously panning doesn't stop the previous panning animation.
  • Fixed a bug where drawing raster files to an unexpected area.
  • Supported Unified API to allow user to build 64bit apps.
  • Added Leader Lines.
map_suite_mobile_for_ios_features_bug_fixes_change_log.1509008200.txt.gz · Last modified: 2017/10/26 08:56 by tgwikiupdate
