map_suite_mobile_for_ios_features_bug_fixes_change_log
Map Suite Mobile For iOS Features & Bug Fixes Change Log
Version 10.0.0.0
Release date: 02/16/2017
Map Suite 10.0 New Features:
  • Synchronize the Core APIs across all Map Suite product line.
  • Allow to use Map Suite product without installer.
  • Simplified the license process.
  • Split the original MapSuite Core assembly by functionality. It allows users to embed required assemblies into their projects.
  • Create a BareBone version package for Map Suite products to allow user to create app with minimum size.
  • Create a Standard version package for Map Suite products to transfer user’s existing project to 10.0 easily.
ThinkGeo.MapSuite.iOS Namespace:
  • Added the support for GeoHatchStyle.
  • Added obfuscation for internal class
  • Added more properties on GPSMarker for customization.
  • Added DrawingQuality on Overlay.
  • Refined the code for requesting cancellation.
  • Added the logic to check Tile is null.
  • Fixed xml namespace bug for TiledWmsRasterSource
  • Fixed tile matrix unit issue for GoogleMap.
  • Fixed the bug that getting stream by uri is null.
  • Fixed WmsOverlay hard code issue.
  • Fixed WmsLayer reading xml issue.
  • Fixed a bug that the HeatStyle not work correctly.
  • Reverted the wrong attribute string from ? to ©
  • Fixed the bug for evaluation days.
  • Fixed repeat adding tile bug.
ThinkGeo.MapSuite Namespace:
  • Added style sheets support.
Version 9.0.0.0
Release date: 06/24/2015
ThinkGeo.MapSuite.iOSEdition Namespace:
  • Fixed a bug where there are something wrong with the map events when it is not full screen.
  • Added RestrictExtent and max/min scales range limits.
  • Added support of requesting tiles image from MapBox services.
  • Fixed a bug where the OperationQueue throws exception after transferring to Unified API.
  • Fixed a bug where the continuously panning doesn't stop the previous panning animation.
  • Fixed a bug where drawing raster files to an unexpected area.
  • Supported Unified API to allow user to build 64bit apps.
  • Added Leader Lines.
map_suite_mobile_for_ios_features_bug_fixes_change_log.1489657907.txt.gz · Last modified: 2017/03/16 09:51 by tgwikiupdate
